When I switch to a channel on live TV by typing numbers (with a sequence on Harmony remote), the channel banner stays in the top right corner now. This just started whereas previously it would dial in the channel and go away. Any ideas on why this started “sticking” up there? Thanks.
This is likely fallout due to the recent changes on the TestFlight beta. Thanks for bringing it up, we'll look into it soon.
Oh okay thanks!
This was resolved in the latest TestFlight beta:
I downloaded the new Beta client on the ATV but am not able to update the server yet as it’s recording. The issue still remains with the latest client. Would it require new server software as well?
The fix is not dependent on the server version.
Does the channel number notification dismiss if you use Channel Up/Down?
I see the issue. It'll get fixed up on the next build.
This should do it:
Yes, that appears to have fixed it. I appreciate it!
