Channel Collections acting strange on iOS
Is anyone else having issues with channel collections on iOS and AppleTV since the latest server update or two (beta)? I have three sources on the DVR server, and I realize that channel collections will default to the source with a higher priority if there are duplicates. All of my collections on the Web UI guide are behaving as they should, but in iOS, I start getting lots of random channels replacing collection channels as if they were duplicates from a higher priority source, but they are not. It’s very weird. I’ve had my exact same setup for over a year, but this only started happening with the last beta server update or two.
ETA: It doesn’t matter if I have the sources in the same order on the apps as ther server, or if I use inherit source priority from the server, collections are still a mess on iOS.
This can happen if your m3u don't have channel-id tags
