Channel Collections: Give more info on dropped channels
Not sure if the guide data makes this impossible, but figured I would ask...
If a channel in a collection is dropped from the DVR, right now, you only get, for example:
This channel (108.1) no longer exists.
For OTA channels, this is fine, but i would love to see a callsign or description for all channels, especially TVE ones. In short, I know what 108.1 is, but i have no idea what 1204 is, or any of the TVE ones, really.
This is not possible.
Oh well - worth a shot. Thanks
@maddox Actually, in thinking about it, would there be a way to publish the default TVE channel numbers somewhere? Even just a list to reference would be a reasonable workaround here, rather than trying to dig through the various guide data / mappings / etc.
Another member has a Google Sheets document that lists the TVE channel number / name. It also has information about each channels stream quality.
TV Everywhere Stream Specs - Google Sheets
Thanks. Completely forgot about that, given I can't access it most times (damned work proxy) :slight_smile:
