I have these collections set up. But all I get on the client side is the standard bullcrap when it comes to collections. See screen shots.
EDIT: The forum software added my screen shots in reverse.
Channel collections must be assigned to clients via the DVR web UI: Clients > Client Settings > Server Side Only > Channel Collections
Thank you, I searched hi and low and theres no explanation on this anywhere. Just complete frustration.
Actually, this is documented in Channels' support documents on the website. From the support article:
Once created, Channel Collections are applied to your devices via Server Side Settings. You can apply them to all of your devices or just specific ones.
How do I change their order?
They are ordered as they are added. You need to decide the order you wish them to appear first, and then add each Channel Collection individually in the order in which you would like them appear.
