Channel Guide not updating after sleep
Device: Chromecast with Google TV
If watching channels and I put the device to sleep, next time I open the app, the channel guide will show each channel but a long grey bar that goes horizontally across for time. Force quiting the app and reopening fixes the problem. It seems like the guide simply doesn’t refresh, when opening it that was the most recently used app previously.
What about if you switch to another tab and switch back, does it update?
Are you using Channels DVR, or HDHR live tv only?
I noticed the same issue yesterday on my Sony Android TV. I closed and re-opebed the app, I don't think changing tabs helped.
What do you mean by "Tabs". All Channels vs HD Channels vs SD Channels?
Going into settings and messing around, then going back to guide doesn't fix the problems.
This is for HDHR Live TV app.
