Channel integration with Sony Bravia
I recently got a Sony Bravia and I like the Google TV interface. I discovered that it supports streaming channel integration for apps that support this, so that when I press TV on the remote I get the channel line up. Very cool.
I use ChannelsDVR for locals though and don't feed those into the TV via coax. Instead I rely on Channels. However, this does not support integration so I have to specifically select the app. That is fine if I watch recorded content (99.999% of the time), but I would be nice to simple press the TV button on the remote and have the Channels live locals available as well.
Is this possible any way?
Just remap the tv button to open channels instead. I'm not near my tv but you can remap buttons on your remote in settings.
The TV button can only be remapped between channels (the internal TV ones) and the various HDMI inputs. It does not allow you to map it to an app. If there is a way please let me know.
Currently I have the Input button mapped to the core apps I use and the first press is for ChannelsTV so it not terrible.
