Channel not working in Channels
I've been trying to access channel 8.1 in Channels. I've been unable to access via AppleTV, iPhone or from the web GUI. I was able to watch it from the HDHomerun app though. When attempting on ATV or iPhone I get "Tuner not Available".
I submitted logs each time it didn't work. Are you able to see what issue I'm running into?
2020/11/04 19:11:55.327912 [SNR] Statistics for ch8.1 WISH-HD: ss=99%,0%-100% snq=99%,0%-100% seq=99%,0%-100% bps=5847650,0-12210976 pps=291,0-1160 neterr=47%
The neterr is not good, and usually means there's a latency issue between the HDHR and DVR on the network. But it could be related to the signal too, which seems to jump down to 0%. If only one channel is affected then I would guess a signal or interference problem.
Is the neterr like that for my other channels?
Doesn't look like it. You can click the Log tab of the DVR web UI and then ctrl+F to search for "[SNR]"
Yep I just did that and didn't see it. I was on my phone when I replied to you.
So if it is only happening for one channel what does that tell you? Is it the channel itself? I just did a rescan as well as switching my priority to use my other HDHomerun. Still getting same thing...same neterr stat.
You can check the signal on my.hdhomerun.com while watching to see what its doing
Does it stream to the official HDHR app?
Enabling diagnostics on my.hdhomerun.com and email [email protected] they might be able to see more details from the HDHR than we are able to.
Ok I’ll play around with it.
Yes I can watch it with the hdhr app.
You can try streaming from Channels app with Tuner Sharing off to see if it can stream directly from HDHR any better.
That didn't work on my iPhone...however
My Living Room ATV4 was setup to not use tuner sharing. I first attempted to watch 8.1 on it and it worked fine. Turned on tuner sharing, tried again, and got the tuner error. Here is the log from the ATV4 if that helps you with anything
2020-11-04 20:34:18.904 [u=183.8MB f=1266.2MB] LTDiscoveryRound: 282faa7c0: started=true
2020-11-04 20:34:19.244 [u=186.7MB f=1263.3MB] LTHTTPClient: GET http://192.168.100.32:8089/status
2020-11-04 20:34:19.304 [u=186.8MB f=1263.2MB] LTPlusDiscoveryManager: appDidBecomeActive: notification=name = UIApplicationDidBecomeActiveNotification, object = Optional(<UIApplication: 0x102607eb0>), userInfo = nil skipDiscoverOnAppActive=false
2020-11-04 20:34:19.630 [u=186.7MB f=1263.3MB] HRDiscoveryRound: 283a2ac00: new discovery round
2020-11-04 20:34:19.638 [u=186.7MB f=1263.3MB] refresh: baseURL=http://192.168.100.32:8089 exists=1 dvrAvailable=1
2020-11-04 20:34:19.647 [u=186.8MB f=1263.2MB] LTHTTPClient: GET http://192.168.100.32:8089/status
2020-11-04 20:34:19.656 [u=186.8MB f=1263.2MB] LTPlusDiscoveryManager: discover: succeeded: search_endpoints=false async_refresh=true state=connected plus_endpoint=Optional(LTFramework.DiscoveryEndpoint(url: http://192.168.100.32:8089, dvrIdentifier: Optional("tY9TKjixO5ENEwPbcMvVl25yoDDan3RUUoUyVpPOD28="), discoveryType: LTFramework.DiscoveryEndpointType.localLastUsed)) time=0.78286975
2020-11-04 20:34:19.664 [u=186.7MB f=1263.3MB] plusServerChange: notification=LTPlusServerRefreshed isActive=0 isDiscovering=0 discoveryCompleted=1
2020-11-04 20:34:19.846 [u=186.9MB f=1263.1MB] LTHTTPClient: GET http://192.168.100.32:8089/auth
2020-11-04 20:34:19.882 [u=186.9MB f=1263.1MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr
2020-11-04 20:34:19.891 [u=186.9MB f=1263.1MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/guide/channels
2020-11-04 20:34:19.900 [u=187.0MB f=1263.0MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/groups
2020-11-04 20:34:19.908 [u=187.0MB f=1263.0MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/programs
2020-11-04 20:34:19.917 [u=187.1MB f=1262.9MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/rules
2020-11-04 20:34:19.925 [u=187.2MB f=1262.8MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files
2020-11-04 20:34:19.934 [u=187.3MB f=1262.7MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files?deleted=1
2020-11-04 20:34:19.986 [u=187.0MB f=1263.0MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/jobs
2020-11-04 20:34:23.876 [u=193.6MB f=1256.4MB] logCustomEventWithName: Guide Loaded: {
    Filter = "All Channels";
    Source = Guide;
2020-11-04 20:34:23.996 [u=193.6MB f=1256.4MB] logContentViewWithName: Guide View (Main View/GuideView): (null)
2020-11-04 20:34:24.004 [u=193.7MB f=1256.3MB] LTTabsManager: setting_last_tab_index: selected_index=1
2020-11-04 20:34:24.145 [u=193.4MB f=1256.6MB] refresh: completed: baseURL=http://192.168.100.32:8089 exists=1 dvrAvailable=1
2020-11-04 20:34:24.155 [u=193.4MB f=1256.6MB] LTHTTPClient: GET http://192.168.100.32:8089/devices
2020-11-04 20:34:24.164 [u=193.4MB f=1256.6MB] LTPlusClient: refreshDevices: url=http://192.168.100.32:8089/devices
2020-11-04 20:34:24.203 [u=193.4MB f=1256.6MB] HRDiscoveryRound: 283a2ac00: discoverFromPlus: devices=["10741424", "104F208B", "TVE-ATTOTT"] time=0.048438
2020-11-04 20:34:24.452 [u=193.7MB f=1256.3MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/10741424/guide?time=1604539878&duration=28800
2020-11-04 20:34:24.463 [u=193.7MB f=1256.2MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/104F208B/guide?time=1604539878&duration=28800
2020-11-04 20:34:24.472 [u=193.8MB f=1256.2MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/TVE-ATTOTT/guide?time=1604539878&duration=28800
2020-11-04 20:34:24.841 [u=192.7MB f=1257.4MB] HRDiscoveryRound: 283a2ac00: discoverFromHDHR: devices=["10741424", "104F208B"] time=0.617326458
2020-11-04 20:34:24.857 [u=193.0MB f=1257.0MB] HRDiscoveryRound: 283a2ac00: update: devices=["10741424", "104F208B", "TVE-ATTOTT"] removed_device_ids=[] time=0.696573542
2020-11-04 20:34:24.870 [u=193.7MB f=1256.3MB] HRClient: refreshGuide: force=false devices=3
2020-11-04 20:34:24.879 [u=194.0MB f=1256.0MB] Refreshing guide data: deviceId=10741424 isPlus=1 isFYI=1 isSnapshot=0 dvrFeatureEnabled=1 subscriptionLocked=0 subscriptionVerified=1
2020-11-04 20:34:24.888 [u=194.0MB f=1256.0MB] Refreshing guide data: deviceId=104F208B isPlus=1 isFYI=1 isSnapshot=0 dvrFeatureEnabled=1 subscriptionLocked=0 subscriptionVerified=1
2020-11-04 20:34:24.895 [u=194.0MB f=1256.0MB] Refreshing guide data: deviceId=TVE-ATTOTT isPlus=1 isFYI=0 isSnapshot=0 dvrFeatureEnabled=1 subscriptionLocked=0 subscriptionVerified=1
2020-11-04 20:34:24.905 [u=193.9MB f=1256.1MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/10741424/guide?time=1604540064&duration=10800
2020-11-04 20:34:24.913 [u=194.0MB f=1256.0MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/104F208B/guide?time=1604540064&duration=10800
2020-11-04 20:34:24.921 [u=194.0MB f=1256.0MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/TVE-ATTOTT/guide?time=1604540064&duration=10800
2020-11-04 20:34:26.421 [u=194.8MB f=1255.2MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/10741424/guide?time=1604550864&duration=28800
2020-11-04 20:34:26.429 [u=194.9MB f=1255.1MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/104F208B/guide?time=1604550864&duration=28800
2020-11-04 20:34:26.437 [u=194.9MB f=1255.1MB] LTHTTPClient: GET http://192.168.100.32:8089/devices/TVE-ATTOTT/guide?time=1604550864&duration=28800
2020-11-04 20:34:26.634 [u=196.0MB f=1254.0MB] Notification: LTGuideDataUpdated
2020-11-04 20:34:31.997 [u=196.8MB f=1253.2MB] App did enter background (2)
2020-11-04 20:34:32.011 [u=196.8MB f=1253.2MB] jsonpipe cancelled
2020-11-04 20:34:33.106 [u=192.4MB f=1257.6MB] App will enter foreground (2)
2020-11-04 20:34:33.125 [u=192.5MB f=1257.5MB] LTPlusDiscoveryManager: discover: started: search_endpoints=false async_refresh=true state=connected plus_endpoint=Optional(LTFramework.DiscoveryEndpoint(url: http://192.168.100.32:8089, dvrIdentifier: Optional("tY9TKjixO5ENEwPbcMvVl25yoDDan3RUUoUyVpPOD28="), discoveryType: LTFramework.DiscoveryEndpointType.localLastUsed))
2020-11-04 20:34:33.136 [u=192.4MB f=1257.6MB] LTDiscoveryRound: 282fcbc30: started=true
2020-11-04 20:34:33.318 [u=195.7MB f=1254.3MB] LTHTTPClient: GET http://192.168.100.32:8089/status
2020-11-04 20:34:33.349 [u=195.8MB f=1254.2MB] LTPlusDiscoveryManager: appDidBecomeActive: notification=name = UIApplicationDidBecomeActiveNotification, object = Optional(<UIApplication: 0x102607eb0>), userInfo = nil skipDiscoverOnAppActive=false
2020-11-04 20:34:33.824 [u=196.2MB f=1253.8MB] HRDiscoveryRound: 283a29340: new discovery round
2020-11-04 20:34:33.832 [u=196.3MB f=1253.7MB] refresh: baseURL=http://192.168.100.32:8089 exists=1 dvrAvailable=1
2020-11-04 20:34:33.840 [u=196.3MB f=1253.7MB] LTHTTPClient: GET http://192.168.100.32:8089/status
2020-11-04 20:34:33.848 [u=196.3MB f=1253.7MB] LTPlusDiscoveryManager: discover: succeeded: search_endpoints=false async_refresh=true state=connected plus_endpoint=Optional(LTFramework.DiscoveryEndpoint(url: http://192.168.100.32:8089, dvrIdentifier: Optional("tY9TKjixO5ENEwPbcMvVl25yoDDan3RUUoUyVpPOD28="), discoveryType: LTFramework.DiscoveryEndpointType.localLastUsed)) time=0.732634917
2020-11-04 20:34:33.857 [u=196.3MB f=1253.7MB] plusServerChange: notification=LTPlusServerRefreshed isActive=0 isDiscovering=0 discoveryCompleted=1
2020-11-04 20:34:34.049 [u=196.4MB f=1253.6MB] LTHTTPClient: GET http://192.168.100.32:8089/auth
2020-11-04 20:34:34.070 [u=196.4MB f=1253.6MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr
2020-11-04 20:34:34.078 [u=196.5MB f=1253.5MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/guide/channels
2020-11-04 20:34:34.086 [u=196.5MB f=1253.5MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/groups
2020-11-04 20:34:34.098 [u=196.6MB f=1253.4MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/programs
2020-11-04 20:34:34.106 [u=196.7MB f=1253.3MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/rules
2020-11-04 20:34:34.115 [u=196.7MB f=1253.3MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files
2020-11-04 20:34:34.123 [u=196.8MB f=1253.2MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files?deleted=1
2020-11-04 20:34:34.249 [u=196.6MB f=1253.4MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/jobs
2020-11-04 20:34:37.949 [u=197.2MB f=1252.8MB] refresh: completed: baseURL=http://192.168.100.32:8089 exists=1 dvrAvailable=1
2020-11-04 20:34:37.959 [u=197.2MB f=1252.8MB] LTHTTPClient: GET http://192.168.100.32:8089/devices
2020-11-04 20:34:37.967 [u=197.3MB f=1252.7MB] LTPlusClient: refreshDevices: url=http://192.168.100.32:8089/devices
2020-11-04 20:34:37.991 [u=197.2MB f=1252.8MB] HRDiscoveryRound: 283a29340: discoverFromPlus: devices=["10741424", "104F208B", "TVE-ATTOTT"] time=0.032433875
2020-11-04 20:34:38.620 [u=197.1MB f=1252.9MB] HRDiscoveryRound: 283a29340: discoverFromHDHR: devices=["10741424", "104F208B"] time=0.603204792
2020-11-04 20:34:38.638 [u=197.1MB f=1252.9MB] HRDiscoveryRound: 283a29340: update: devices=["10741424", "104F208B", "TVE-ATTOTT"] removed_device_ids=[] time=0.672112792
2020-11-04 20:34:38.652 [u=197.1MB f=1252.9MB] HRClient: refreshGuide: force=false devices=3
2020-11-04 20:34:38.663 [u=197.1MB f=1252.9MB] HRDevice: refreshGuideDataIfNeeded: not_needed: deviceId=10741424
2020-11-04 20:34:38.672 [u=197.2MB f=1252.8MB] HRDevice: refreshGuideDataIfNeeded: not_needed: deviceId=104F208B
2020-11-04 20:34:38.680 [u=197.2MB f=1252.8MB] HRDevice: refreshGuideDataIfNeeded: not_needed: deviceId=TVE-ATTOTT
2020-11-04 20:34:48.210 [u=199.1MB f=1250.9MB] [cplayer] v: Set property: pause=true -> 1
2020-11-04 20:34:48.346 [u=199.6MB f=1250.4MB] Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateStopped
2020-11-04 20:34:48.472 [u=200.3MB f=1249.7MB] logCustomEventWithName: Play Channel: {
    Source = "Guide View Item Cell";
2020-11-04 20:34:48.511 [u=199.9MB f=1250.1MB] Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateLoading
2020-11-04 20:34:48.523 [u=200.0MB f=1250.0MB] set streaming buffer to 146 segments (free bytes: 10590703616)
2020-11-04 20:34:48.537 [u=200.1MB f=1249.9MB] streamer sent request to 192.168.100.11: tuner 3, channel <HRChannel:0x281f99770 number=8.1 name=CW (WISH-HD)> []
2020-11-04 20:34:48.541 [u=200.1MB f=1249.9MB] logCustomEventWithName: Guide Loaded: {
    Source = Guide;
2020-11-04 20:34:48.638 [u=201.1MB f=1248.9MB] logContentViewWithName: Guide View (Main View/GuideView): (null)
2020-11-04 20:34:49.066 [u=204.9MB f=1245.1MB] event: start-file
2020-11-04 20:34:49.078 [u=204.9MB f=1245.1MB] Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateLoading
2020-11-04 20:34:49.091 [u=204.9MB f=1245.1MB] [cplayer] info: Playing: cb://1604540088514
2020-11-04 20:34:49.100 [u=204.9MB f=1245.1MB] IS PAUSED = NO
2020-11-04 20:34:49.108 [u=204.9MB f=1245.1MB] [stream_callback] v: Opening cb://1604540088514
2020-11-04 20:34:49.118 [u=204.9MB f=1245.1MB] [demux] v: Trying demuxers for level=force.
2020-11-04 20:34:49.246 [u=204.9MB f=1245.1MB] streamer started receiving data
2020-11-04 20:34:49.285 [u=205.0MB f=1245.0MB] [lavf] v: Found 'mpegts' at score=50 size=2048.
2020-11-04 20:34:49.297 [u=205.4MB f=1244.6MB] event: tracks-changed
2020-11-04 20:34:49.307 [u=205.5MB f=1244.5MB] Preferred audio tracks (US/en/eng): (
        albumart = 0;
        codec = ac3;
        "decoder-desc" = "ac3 (ATSC A/52A (AC-3))";
        default = 0;
        dependent = 0;
        "display-title" = English;
        external = 0;
        "ff-index" = 1;
        forced = 0;
        "hearing-impaired" = 0;
        id = 1;
        lang = eng;
        priority = 500;
        selected = 1;
        "src-id" = 52;
        type = audio;
        "visual-impaired" = 0;
        albumart = 0;
        codec = ac3;
        default = 0;
        dependent = 0;
        "display-title" = Spanish;
        external = 0;
        "ff-index" = 2;
        forced = 0;
        id = 2;
        lang = spa;
        priority = 100;
        selected = 0;
        "src-id" = 53;
        type = audio;
2020-11-04 20:34:49.318 [u=205.5MB f=1244.5MB] event: tracks-changed
2020-11-04 20:34:49.330 [u=205.5MB f=1244.5MB] event: tracks-changed
2020-11-04 20:34:49.341 [u=205.5MB f=1244.5MB] event: metadata-update
2020-11-04 20:34:49.351 [u=205.5MB f=1244.5MB] event: audio-reconfig
2020-11-04 20:34:49.360 [u=205.6MB f=1244.4MB] event: audio-reconfig
2020-11-04 20:34:49.370 [u=205.6MB f=1244.4MB] event: file-loaded
2020-11-04 20:34:49.382 [u=205.6MB f=1244.4MB] [lavf] v: avformat_open_input() finished after 2048 bytes.
2020-11-04 20:34:49.392 [u=205.7MB f=1244.3MB] IS BUFFERING = NO
2020-11-04 20:34:49.410 [u=205.9MB f=1244.1MB] [lavf] v: avformat_find_stream_info() skipped
2020-11-04 20:34:49.428 [u=206.5MB f=1243.5MB] [demux] v: Detected file format: mpegts (libavformat)
2020-11-04 20:34:49.447 [u=206.9MB f=1243.1MB] [cplayer] v: Opening done: cb://1604540088514
2020-11-04 20:34:49.457 [u=207.0MB f=1243.0MB] [lavf] v: select track 0
2020-11-04 20:34:49.467 [u=207.1MB f=1242.9MB] [lavf] v: select track 1
2020-11-04 20:34:49.475 [u=207.1MB f=1242.9MB] [cplayer] info:  (+) Video --vid=1 (mpeg2video)
2020-11-04 20:34:49.513 [u=207.1MB f=1242.9MB] [cplayer] info:  (+) Audio --aid=1 --alang=eng (ac3)
2020-11-04 20:34:49.557 [u=207.1MB f=1242.9MB] [cplayer] info:      Audio --aid=2 --alang=spa (ac3)
2020-11-04 20:34:49.562 [u=206.9MB f=1243.1MB] logContentViewWithName: Video View (Main View/VideoView): (null)
2020-11-04 20:34:49.584 [u=206.9MB f=1243.1MB] [vd] v: Container reported FPS: 0.000000
2020-11-04 20:34:49.626 [u=207.1MB f=1242.9MB] [vd] v: Codec list:
2020-11-04 20:34:49.635 [u=207.1MB f=1242.9MB] [vd] v:     mpeg2video - MPEG-2 video
2020-11-04 20:34:49.650 [u=207.5MB f=1242.5MB] event: audio-reconfig
2020-11-04 20:34:49.684 [u=207.5MB f=1242.5MB] [vd] v:     mpegvideo (mpeg2video) - MPEG-1 video
2020-11-04 20:34:49.710 [u=207.5MB f=1242.5MB] [vd] v: Opening decoder mpeg2video
2020-11-04 20:34:49.725 [u=207.5MB f=1242.5MB] [vd] v: Not trying to use hardware decoding: codec mpeg2video is not on whitelist.
2020-11-04 20:34:49.763 [u=207.5MB f=1242.5MB] [vd] v: Using software decoding.
2020-11-04 20:34:49.785 [u=213.2MB f=1236.8MB] [vd] v: Detected 2 logical cores.
2020-11-04 20:34:49.794 [u=213.2MB f=1236.8MB] [vd] v: Requesting 3 threads for decoding.
2020-11-04 20:34:49.804 [u=213.2MB f=1236.8MB] [vd] v: Selected codec: mpeg2video (MPEG-2 video)
2020-11-04 20:34:49.812 [u=213.2MB f=1236.8MB] [vf] v: User filter list:
2020-11-04 20:34:49.821 [u=213.2MB f=1236.8MB] [vf] v:   lavfi (lavfi.00)
2020-11-04 20:34:49.829 [u=213.2MB f=1236.8MB] [ad] v: Codec list:
2020-11-04 20:34:49.837 [u=213.2MB f=1236.8MB] [ad] v:     ac3 - ATSC A/52A (AC-3)
2020-11-04 20:34:49.845 [u=213.2MB f=1236.8MB] [ad] v:     ac3_fixed (ac3) - ATSC A/52A (AC-3)
2020-11-04 20:34:49.853 [u=213.2MB f=1236.8MB] [ad] v:     ac3_at (ac3) - ac3 (AudioToolbox)
2020-11-04 20:34:49.860 [u=213.2MB f=1236.8MB] [ad] v: Opening decoder ac3
2020-11-04 20:34:49.869 [u=213.2MB f=1236.8MB] [ad] v: Requesting 1 threads for decoding.
2020-11-04 20:34:49.877 [u=213.2MB f=1236.8MB] [ad] v: Selected codec: ac3 (ATSC A/52A (AC-3))
2020-11-04 20:34:49.885 [u=213.2MB f=1236.8MB] [af] v: User filter list:
2020-11-04 20:34:49.892 [u=213.2MB f=1236.8MB] [af] v:   (empty)
2020-11-04 20:34:49.900 [u=213.2MB f=1236.8MB] [cplayer] v: Starting playback...
2020-11-04 20:34:49.908 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.917 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.934 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.941 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.949 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.957 [u=213.2MB f=1236.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.967 [u=213.4MB f=1236.6MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.978 [u=213.6MB f=1236.3MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.989 [u=219.4MB f=1230.6MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:49.998 [u=225.4MB f=1224.6MB] event: video-reconfig
2020-11-04 20:34:50.010 [u=228.8MB f=1221.2MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:50.020 [u=230.5MB f=1219.5MB] event: tracks-changed
2020-11-04 20:34:50.029 [u=230.5MB f=1219.5MB] event: video-reconfig
2020-11-04 20:34:50.039 [u=230.5MB f=1219.5MB] [af] v: [in] 48000Hz 5.1(side) 6ch floatp
2020-11-04 20:34:50.048 [u=228.8MB f=1221.2MB] [af] v: [userspeed] 48000Hz 5.1(side) 6ch floatp
2020-11-04 20:34:50.056 [u=228.8MB f=1221.2MB] [af] v: [userspeed] (disabled)
2020-11-04 20:34:50.064 [u=228.8MB f=1221.2MB] [af] v: [convert] 48000Hz 5.1(side) 6ch floatp
2020-11-04 20:34:50.073 [u=228.8MB f=1221.2MB] [ao] v: Trying audio driver 'audiounit'
2020-11-04 20:34:50.081 [u=227.1MB f=1222.9MB] [ao/audiounit] v: requested format: 48000 Hz, 5.1(side) channels, floatp
2020-11-04 20:34:50.089 [u=227.1MB f=1222.9MB] [ao/audiounit] v: using soft-buffer of 9600 samples.
2020-11-04 20:34:50.097 [u=227.1MB f=1222.9MB] [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2020-11-04 20:34:50.109 [u=227.1MB f=1222.9MB] [cplayer] v: AO: Description: AudioUnit (iOS)
2020-11-04 20:34:50.126 [u=227.1MB f=1222.9MB] [autoconvert] v: inserting resampler
2020-11-04 20:34:50.142 [u=227.1MB f=1222.9MB] [swresample] v: format change, reinitializing resampler
2020-11-04 20:34:50.153 [u=227.1MB f=1222.9MB] [swresample] v: 48000Hz 5.1(side) floatp -> 48000Hz stereo floatp
2020-11-04 20:34:50.163 [u=227.1MB f=1222.9MB] [swresample] v: Remix: 5.1(side) -> stereo
2020-11-04 20:34:50.172 [u=227.1MB f=1222.9MB] [af] v: [out] 48000Hz stereo 2ch floatp
2020-11-04 20:34:50.179 [u=227.1MB f=1222.9MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:50.187 [u=227.1MB f=1222.9MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:50.195 [u=227.1MB f=1222.9MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:50.203 [u=227.2MB f=1222.8MB] [vd] warn: Error while decoding frame (-1094995529)!
2020-11-04 20:34:50.211 [u=227.2MB f=1222.8MB] [vd] v: DR failed - disabling.
2020-11-04 20:34:50.220 [u=227.2MB f=1222.8MB] [vd] v: Decoder format: 1920x1080 yuv420p auto/auto/auto/limited/auto CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
2020-11-04 20:34:50.229 [u=227.2MB f=1222.8MB] [vf] v: [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.236 [u=227.2MB f=1222.8MB] [vf] v: [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.245 [u=227.2MB f=1222.8MB] [vf] v: [userdeint] (disabled)
2020-11-04 20:34:50.252 [u=227.2MB f=1222.8MB] [vf] v: [lavfi] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.260 [u=227.2MB f=1222.8MB] [vf] v: [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.269 [u=227.2MB f=1222.8MB] [vf] v: [autorotate] (disabled)
2020-11-04 20:34:50.276 [u=227.2MB f=1222.8MB] [vf] v: [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.285 [u=227.2MB f=1222.8MB] [vf] v: [convert] (disabled)
2020-11-04 20:34:50.292 [u=227.2MB f=1222.8MB] [vf] v: [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.300 [u=227.2MB f=1222.8MB] [cplayer] info: VO: [libmpv] 1920x1080 yuv420p
2020-11-04 20:34:50.309 [u=227.2MB f=1222.8MB] [cplayer] v: VO: Description: render API for libmpv
2020-11-04 20:34:50.317 [u=227.2MB f=1222.8MB] [vo/libmpv] v: reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
2020-11-04 20:34:50.326 [u=227.2MB f=1222.8MB] [cplayer] v: first video frame after restart shown
2020-11-04 20:34:50.334 [u=227.2MB f=1222.8MB] [cplayer] info:  (+) Video --vid=1 (mpeg2video)
2020-11-04 20:34:50.342 [u=227.2MB f=1222.8MB] [cplayer] info:  (+) Audio --aid=1 --alang=eng (ac3)
2020-11-04 20:34:50.350 [u=227.2MB f=1222.8MB] [cplayer] info:      Audio --aid=2 --alang=spa (ac3)
2020-11-04 20:34:50.359 [u=227.2MB f=1222.8MB] [cplayer] info:      Subs  --sid=1 (*) (eia_608)
2020-11-04 20:34:50.878 [u=227.3MB f=1222.7MB] [cplayer] v: starting audio playback
2020-11-04 20:34:50.888 [u=231.9MB f=1218.0MB] event: playback-restart
2020-11-04 20:34:50.913 [u=233.4MB f=1216.6MB] Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStatePlaying
2020-11-04 20:34:50.962 [u=236.4MB f=1213.6MB] [cplayer] v: playback restart complete @ 33554.117922
2020-11-04 20:34:53.632 [u=243.7MB f=1206.3MB] read got (9) Bad file descriptor
2020-11-04 20:34:53.638 [u=243.7MB f=1206.3MB] Updating playState from LTVideoPlayerPlayStatePlaying to LTVideoPlayerPlayStateStopped
2020-11-04 20:34:53.644 [u=243.7MB f=1206.3MB] streamer stopping after 1700 packets and 1 timeouts (77 waits)
2020-11-04 20:34:53.648 [u=243.8MB f=1206.2MB] Shake handler changed (0), resetting game controllers
2020-11-04 20:34:53.661 [u=243.6MB f=1206.4MB] [lavf] v: EOF reached.
2020-11-04 20:34:53.679 [u=243.6MB f=1206.4MB] logCustomEventWithName: Guide Loaded: {
    Source = Guide;
2020-11-04 20:34:53.859 [u=206.5MB f=1243.5MB] event: audio-reconfig
2020-11-04 20:34:53.881 [u=206.7MB f=1243.3MB] event: video-reconfig
2020-11-04 20:34:53.890 [u=206.7MB f=1243.3MB] event: tracks-changed
2020-11-04 20:34:53.899 [u=206.7MB f=1243.3MB] event: end-file: {
    error = 0;
    reason = 2;
2020-11-04 20:34:53.908 [u=206.8MB f=1243.2MB] end-file: playlistCount:0
2020-11-04 20:34:53.918 [u=206.7MB f=1243.3MB] event: audio-reconfig
2020-11-04 20:34:53.928 [u=206.7MB f=1243.3MB] event: video-reconfig
2020-11-04 20:34:54.001 [u=206.8MB f=1243.2MB] [cplayer] v: EOF code: 4
2020-11-04 20:34:54.010 [u=206.8MB f=1243.2MB] IS PAUSED = YES
2020-11-04 20:34:54.019 [u=206.7MB f=1243.3MB] [ad] v: Uninit decoder.
2020-11-04 20:34:54.027 [u=206.7MB f=1243.3MB] [vd] v: Uninit decoder.
2020-11-04 20:34:54.036 [u=206.7MB f=1243.3MB] [cplayer] v: finished playback, success (reason 2)
2020-11-04 20:34:54.045 [u=206.7MB f=1243.3MB] [cplayer] info:
2020-11-04 20:34:54.054 [u=206.7MB f=1243.3MB] [cplayer] v: Set property: aid=1 -> 1
2020-11-04 20:34:54.062 [u=206.7MB f=1243.3MB] [cplayer] v: Set property: audio=1 -> 1
2020-11-04 20:34:54.071 [u=206.7MB f=1243.3MB] [cplayer] v: Set property: sid=0 -> 1
2020-11-04 20:34:54.080 [u=206.7MB f=1243.3MB] [cplayer] v: Set property: sub=0 -> 1
2020-11-04 20:34:54.433 [u=206.9MB f=1243.1MB] logContentViewWithName: Guide View (Main View/GuideView): (null)
2020-11-04 20:34:56.569 [u=204.6MB f=1245.4MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files/3507
2020-11-04 20:35:05.142 [u=202.1MB f=1247.9MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr
2020-11-04 20:35:05.151 [u=202.1MB f=1247.9MB] LTHTTPClient: GET http://192.168.100.32:8089/status
2020-11-04 20:35:05.160 [u=202.2MB f=1247.8MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files?deleted=1
2020-11-04 20:35:05.335 [u=202.3MB f=1247.7MB] LTTabsManager: setting_last_tab_index: selected_index=6
2020-11-04 20:35:05.380 [u=202.9MB f=1247.1MB] LTHTTPClient: GET http://192.168.100.32:8089/auth
2020-11-04 20:35:18.557 [u=207.5MB f=1242.5MB] LTHTTPClient: GET http://192.168.100.32:8089/dvr/files/3507
2020-11-04 20:35:20.974 [u=207.5MB f=1242.5MB] logCustomEventWithName: Guide Loaded: {
    Source = Guide;
2020-11-04 20:35:21.167 [u=210.7MB f=1239.3MB] logContentViewWithName: Guide View (Main View/GuideView): (null)
2020-11-04 20:35:21.175 [u=210.7MB f=1239.3MB] LTTabsManager: setting_last_tab_index: selected_index=1
2020-11-04 20:35:22.650 [u=210.2MB f=1239.8MB] [cplayer] v: Set property: pause=true -> 1
2020-11-04 20:35:22.664 [u=210.2MB f=1239.8MB] Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateStopped
2020-11-04 20:35:22.778 [u=210.4MB f=1239.6MB] logCustomEventWithName: Play Channel: {
2020-11-04 20:35:22.810 [u=210.3MB f=1239.7MB] Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateLoading
2020-11-04 20:35:22.819 [u=210.4MB f=1239.6MB] set streaming buffer to 146 segments (free bytes: 10588594176)
2020-11-04 20:35:22.830 [u=210.4MB f=1239.6MB] streamer sent request to DVR 192.168.100.32: device 10741424, channel <HRChannel:0x281f99770 number=8.1 name=CW (WISH-HD)> [/devices/10741424/channels/8.1/stream.mpg?codec=copy]
2020-11-04 20:35:22.836 [u=210.4MB f=1239.6MB] logCustomEventWithName: Guide Loaded: {
    Source = Guide;
2020-11-04 20:35:22.930 [u=210.7MB f=1239.3MB] logContentViewWithName: Guide View (Main View/GuideView): (null)
2020-11-04 20:35:23.318 [u=213.7MB f=1236.3MB] event: start-file
2020-11-04 20:35:23.331 [u=213.7MB f=1236.3MB] Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateLoading
2020-11-04 20:35:23.341 [u=213.7MB f=1236.3MB] [cplayer] info: Playing: cb://1604540122810
2020-11-04 20:35:23.350 [u=213.7MB f=1236.3MB] IS PAUSED = NO
2020-11-04 20:35:23.359 [u=213.7MB f=1236.3MB] [stream_callback] v: Opening cb://1604540122810
2020-11-04 20:35:23.368 [u=213.7MB f=1236.3MB] [demux] v: Trying demuxers for level=force.
2020-11-04 20:35:23.856 [u=213.8MB f=1236.2MB] logContentViewWithName: Video View (Main View/VideoView): (null)
2020-11-04 20:35:28.738 [u=210.4MB f=1239.6MB] read(2048) = 0 after 5000000
2020-11-04 20:35:34.162 [u=212.5MB f=1237.5MB] read(2048) = 0 after 5000000
2020-11-04 20:35:34.190 [u=210.5MB f=1239.5MB] read got (9) Bad file descriptor
2020-11-04 20:35:34.199 [u=210.5MB f=1239.6MB] [lavf] v: No format found, try lowering probescore or forcing the format.
2020-11-04 20:35:34.208 [u=210.4MB f=1239.6MB] streamer stopping after 0 packets and 1 timeouts (200 waits)
2020-11-04 20:35:34.214 [u=210.4MB f=1239.6MB] event: tracks-changed
2020-11-04 20:35:34.229 [u=210.4MB f=1239.6MB] event: end-file: {
    error = "-17";
    reason = 4;
2020-11-04 20:35:34.238 [u=210.6MB f=1239.4MB] end-file: playlistCount:1
2020-11-04 20:35:34.248 [u=210.7MB f=1239.3MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.270 [u=210.6MB f=1239.4MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.279 [u=210.6MB f=1239.4MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.288 [u=210.6MB f=1239.4MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.297 [u=210.7MB f=1239.3MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.306 [u=210.7MB f=1239.3MB] Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:34.314 [u=210.8MB f=1239.2MB] Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateError
2020-11-04 20:35:34.321 [u=210.8MB f=1239.2MB] [cplayer] v: Opening failed or was aborted: cb://1604540122810
2020-11-04 20:35:34.336 [u=211.1MB f=1238.9MB] IS PAUSED = YES
2020-11-04 20:35:34.346 [u=211.2MB f=1238.8MB] [cplayer] v: finished playback, unrecognized file format (reason 4)
2020-11-04 20:35:34.356 [u=211.4MB f=1238.6MB] [cplayer] error: Failed to recognize file format.
2020-11-04 20:35:34.366 [u=211.4MB f=1238.6MB] [cplayer] info:
2020-11-04 20:35:34.374 [u=211.4MB f=1238.6MB] [cplayer] v: Set property: aid=1 -> 1
2020-11-04 20:35:34.381 [u=211.4MB f=1238.6MB] [cplayer] v: Set property: audio=1 -> 1
2020-11-04 20:35:34.389 [u=211.4MB f=1238.6MB] [cplayer] v: Set property: sid=0 -> 1
2020-11-04 20:35:34.396 [u=211.4MB f=1238.6MB] [cplayer] v: Set property: sub=0 -> 1
2020-11-04 20:35:37.288 [u=211.3MB f=1238.7MB] actually showing Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:37.309 [u=211.3MB f=1238.7MB] actually showing Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:37.323 [u=211.7MB f=1238.3MB] actually showing Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:37.336 [u=211.7MB f=1238.3MB] actually showing Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:37.347 [u=211.7MB f=1238.3MB] actually showing Video Error Message: ⚠️ Tuner Not Available
2020-11-04 20:35:37.356 [u=211.7MB f=1238.3MB] actually showing Video Error Message: ⚠️ Tuner Not Available
Seems like the DVR can't keep a stable connection to the HDHR for that channel for some strange reason then..
Check the cables I guess? Are the NAS and HDHR plugged into the same switch?
