Running Channels 3.1.15 on 3 AppleTV 4’s in our house, connected to an HDHomerun Connect Duo. All connections are ethernet. Around the time 3.1.15 came out, the app purged all channel info for all three installations. Scanning again finds the 186 channels it should be finding while the scan is progressing, then immediately purges them all and shows 0 channels available as soon as the scan completes. All AppleTV’s are running tvOs 11.3 (15L211).
Restarting all devices, and deleting and reinstalling Channels has not resolved the problem.
The HDHomerun is running the latest firmware. I should also mention the HDHomerun app on both macOs and Windows shows all channels and streams them fine.
Suggestions?
