Has anyone tried to channel surf across virtual channels? If I go to a TVE channel and channel surf it works fine. If I surf into a virtual channel it works fine. However, once I am on a virtual channel I can no long change the channel using the channel up and down buttons. Is this a bug or expected behavior? I am using Channels DVR 4.0.1 for android TV on a Sony tv with android version 9. I submitted a diagnostics report as well. I'm on server 2021.11.20.2226.
This is a bug. It will be fixed in the next beta apk.
Awesome thanks!
