Channels 6.0.1 on tvOS 18.1b1 Crash
Crashes upon launch.
Would you mind sending us one of the crash logs at [email protected]
Did it crash on tvOS 18.0? We appreciate the notice, but more details would be a lot more helpful.
Unfortunately, the analytics airdrop share from tvOS to any of my other devices is not working, even with airdrop for everyone enabled.
I did use Feedback Assistant to get a sysdiagnose log. File too large to send via email, so sent an iCloud link via email with a link to this thread as subject.
I do have share analytics with developers enabled on my ATV, but not sure how that gets routed to you.
Got it, thanks!
@maddox
I read in some other threads, there might be a TestFlight release that fixes this problem?
Or is this a different problem?
I only see links for Channels DVR TestFlight.
Is there a TestFlight for the non-DVR version of Channels?
Only for DVR subscribers, AFAIK
You could do a Trial sub
The issue that the latest version resolves is an issue that only those with DVR features would have.
@elvisimprsntr if you’re still running into this, please try deleting and re-installing the app. We believe we have the fix in the latest TestFlight beta, but I suspect it will work around the issue you’re running into if you delete the app.
@eric
That worked. Thanks.
