@maddox I sent Casey an email about a callsheet quirk with channels that he punted back to you guys and sent me to you if you can please take a look
This was my email to him:
When clicking on a now playing show, some shows will take you to exact episode vs some shows that takes you to a search result and have to manually find nthe show, season and episode page.
Here are some pics:
Vs.
This was his response:
It’s been a minute since I’ve looked at this code, but basically, if Channels provides me a show, season, and episode number, I’ll use them. If that’s the case, I'll jump you directly to that episode. If Channels doesn’t provide them, then the best I can do is just show you a search result for the name of the show, which I always have.
If memory serves, Channels does not always determine the exact show ID number I need, and sometimes not the season nor episode numbers either. If they don’t have it, I don’t get it. So, I do the best I can with what I’ve got.
I’m sorry. Feel free to reach out to them if you want this to improve; tell Jon I sent you.
Thanks for taking a look at it. This integration between apps is probably the most underrated and unknown feature. It’s an invaluable eco system. Hope you guys figure out other functions to make it better.
