Updated to 3.13.1651
Also, I finally setup remote access to the computer I mod the app on, so updates will be more frequent.
Bump to 3.22.1228
Filesynced is no more, it corrupts the download sometimes
It appears the Google Drive link to the new .apk file is not working correctly.
I'll have a look today, update it.
Thanks! Appreciate your work. So much better than purple!
Correct, the link is broken. I didn't delete the file from my Drive and this has happened several times before when I knew I didn't delete it. Google is removing it after some time for some reason. (perhaps the developers are requesting that it be) @tmm1
Also, something has changed. The latest beta will not decompile with the methods I have been using. Perhaps the android framework in the app has been updated, and my apktool.jar doesn't support it. Investigating.
EDIT - upgrading to apktool2.9.3.jar has decompiled it
so much code has changed since I themed it last that I may be starting over, or at least backtracking some. I believe the developers are having my themed version removed from my drive, and purposely changed enough code to throw a hitch in our themes.
testers are welcome, DM me
CONFIRMED
This is a decompile of the current beta .apk then a recompile changing ABSOLUTELY NOTHING. I don't care about your PC responses @maddox and @tmm1
You're going to blame me for not being able to successfully decompile then recompile the .apk with zero changes? I don't buy that. If anything, I'm wrong, and it wasn't on purpose, BUT, your code will not recompile. NOT MINE
Decompiling APK file... (Press ESC to cancel)
Command: java.exe -jar "C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\Apktool\apktool_2.9.3.jar" d -f --only-main-classes -o "C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016" "C:\Users\Motherfucker\Downloads\channels-dvr-504251016.apk"
Compiling APK file... (Press ESC to cancel)
Command: java.exe -jar "C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\Apktool\apktool_2.9.3.jar" b -f --use-aapt2 -o "C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\2-Recompiled APKs\channels-dvr-504251016.apk" "C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016"
I: Using Apktool 2.9.3
I: Smaling smali folder into classes.dex...
I: Smaling smali_classes2 folder into classes2.dex...
I: Building resources...
W: C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016\res\values\styles.xml:1449: error: expected dimension but got (raw string) -1.
W: C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016\res\values\styles.xml:1758: error: expected enum but got (raw string) 0.
W: error: failed linking references.
brut.androlib.exceptions.AndrolibException: brut.common.BrutException: could not exec (exit code = 1): [C:\Users\MOTHER~1\AppData\Local\Temp\brut_util_Jar_180943365676384153248419474167225571761.tmp, link, -o, C:\Users\MOTHER~1\AppData\Local\Temp\APKTOOL11345980231001034739.tmp, --package-id, 127, --min-sdk-version, 22, --target-sdk-version, 33, --version-code, 504251016, --version-name, 4.6.7-v504251016, --no-auto-version, --no-version-vectors, --no-version-transitions, --no-resource-deduping, --allow-reserved-package-id, --no-compile-sdk-metadata, --warn-manifest-validation, -e, C:\Users\MOTHER~1\AppData\Local\Temp\APKTOOL6514666542113380398.tmp, -0, arsc, -I, C:\Users\Motherfucker\AppData\Local\apktool\framework\1.apk, --manifest, C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016\AndroidManifest.xml, C:\Users\Motherfucker\Downloads\APK_Easy_Tool_v1.60_Portable\APK_Easy_Tool_v1.60_Portable\1-Decompiled APKs\channels-dvr-504251016\build\resources.zip]
Compile failed. Please read the log
We have not requested anything from Google.
As you can see on the release notes we are upgrading Android Studio dependencies as required to continue operating in the Google play store. Probably apktool doesn't work with newer Android studio yet.
If we could only get this for tvOS...
Better yet, natively in all releases.
Seriously Fancybits, why not?
Still a no-go Can't decompile / recompile the apk with zero changes using latest apktool
C:\Windows>apktool decode channels.apk
I: Using Apktool 2.10.0 on channels.apk with 4 thread(s).
I: Baksmaling classes.dex...
I: Baksmaling classes2.dex...
I: Loading resource table...
I: Decoding file-resources...
I: Loading resource table from file: C:\Users\Motherfucker\AppData\Local\apktool\framework\1.apk
I: Decoding values / XMLs...
I: Decoding AndroidManifest.xml with resources...
I: Regular manifest package...
I: Copying assets and libs...
I: Copying unknown files...
I: Copying original files...
I: Copying META-INF/services directory
C:\Windows>apktool b channels
I: Using Apktool 2.10.0 with 4 thread(s).
I: Checking whether sources has changed...
I: Checking whether resources has changed...
W: C:\Windows\channels\AndroidManifest.xml:1: error: attribute android:requiredSplitTypes not found.
W: C:\Windows\channels\AndroidManifest.xml:1: error: attribute android:splitTypes not found.
W: error: failed processing manifest.
brut.androlib.exceptions.AndrolibException: brut.common.BrutException: could not exec (exit code = 1): [C:\Users\MOTHER~1\AppData\Local\Temp\brut_util_Jar_171160809098891655265271124220602700933.tmp, link, -o, C:\Users\MOTHER~1\AppData\Local\Temp\APKTOOL11388333522113708597.tmp, --package-id, 127, --min-sdk-version, 22, --target-sdk-version, 34, --version-code, 509181717, --version-name, 4.8.0.beta-v509181717, --no-auto-version, --no-version-vectors, --no-version-transitions, --no-resource-deduping, --allow-reserved-package-id, --no-compile-sdk-metadata, --warn-manifest-validation, -e, C:\Users\MOTHER~1\AppData\Local\Temp\APKTOOL8833293241831739132.tmp, -0, arsc, -I, C:\Users\Motherfucker\AppData\Local\apktool\framework\1.apk, --manifest, C:\Windows\channels\AndroidManifest.xml, C:\Windows\channels\build\resources.zip]
update, install as usual
Would anyone like to collaborate on a way to make this easier for someone else to come up with their own theme?
This is the main colors file.
https://drive.google.com/file/d/1OLBZS67PKRwWVBMVKnqhPLLeNYJgjBM7/view?usp=sharing
Unfortunately I wasn't able to create the theme without editing other files, so the goal would be to ONLY edit this file for the desired results. Each variable in the file corresponds to different UI elements in the app with its color HEX code. Not all variables get changed. By changing the HEX color code, you change that specific UI element's color. I will have to map out which variable corresponds to which UI element, unfortunately it's all in my head, and I didn't record any of it, I just remember. So, having a master list of what to change to change what colors is 1st priority. Then perhaps an app that loads the colors.xml, with a picture of the UI, and by clicking on each line in the colors file it will show you what that variable controls. Also the ability to change the hex value, and see the desired results in the same app without having to recompile, and reinstall just to see what changed. It was a ton of trial and error creating this, I'm thinking between 150 and 200 hours of work, so I would like to simplify the process of creating your own custom theme. My coding skills are defunct, and outdated.
Thanks,
Brian
WIP POST
Current colors.xml edits:
name="background">#ff121212
name="deep_dark_purple">#ff000000
name="dvr_setup_bg">#ff101010
name="error_text">#ffeeeeee
name="extra_light_purple">#ffeeeeee
name="fastlane_background">#ff4a4a4a
name="gray">#ff212121
name="guide_subtitle">#ffeeeeee
name="guide_title">#ffeeeeee
name="lb_page_indicator_dot">#ff424242
name="light_purple">#ffababab
name="modal_bg">#ff101010
name="modal_button_focused">#ff4a4a4a
name="muted_dark_purple">#ff000000
name="on_now_cell_bg_color">#ff424242
name="on_now_cell_bg_color_selected">#ff000000
name="pill_color_special">#ff4a4a4a
name="pill_text_special">#ffeeeeee
name="purple">#ff4a4a4a
name="queued_text">#ff000000
name="recording_text">#ff000000
name="settings_cell_bg">#ff101010
name="tab_normal">#ffeeeeee
name="timeline_bg">#ffffffff
name="timeline_buffer">#ffababab
name="timeline_played">#ff4a4a4a
name="tint">#ff4a4a4a
name="warning_text">#ffeeeeee
WIP COLOR MAP
default values listed
name="background">#ff191222
main background in all screens (except modal popups), including the guide grid
name="deep_dark_purple">#ff170b2a
text color in modal popups
name="dvr_setup_bg">#ffeeeeee
background of dvr cannot be found screen
name="extra_light_purple">#ffd6c0f9
most of the in-app text (guide, on now station + ch#, more)
name="fastlane_background">#ff703bc8
grid background for top row selectable items in 'on now', other screens, but not the guide
I had forgotten how awesome this version of Channels looks! The black, the transparent things.
Dug out my old Chromecast with GTV to mess with, sideloaded this most recent apk.
I also forgot how spoiled i have been using Channels on Apple TV for so long...it is just so much better.
With the only exception being the insane seek/scrubbing speed on Android based devices. That also seems way more stable/constant (skipping/scrubbing) for some reason.
Android also does not have Personal Sections yet.
Really really wish the devs would make this kinda theme a option for Apple users.
Hmm, I often find the seek/scrubbing speed on my AndroidTV devices to be too fast, erratic and unreliable. On the AppleTV it's much more precise and usable, at least with the latest Siri remote. It's just easier to get where I intend to go, whereas with AndroidTV it's more of an exercise in frustration. That's been my experience, at least.
Agreed
On this CCGTV and the Nvidia Shields i have, single presses to skip work perfect ever time. Holding down button, seek speed is wicked fast after a couple secs. Though, i could see how this may be too fast for some. But, it is just much faster than Apple TV and would be usefull to have such speed when i want to seek to near the end of long recordings or files etc.
The Siri remote, ever since i have owned Apple TV's, never last more than about 6 months, and the buttons get either mushy or crunchy, and, since i skip fwd ALOT, the right button on D pad always develops a double or even triple press issue. So i have to exchange the remote under store Replacement warranty often. This is the most current Siri remote. Apple needs to use better quality button hardware in their remote. I haven't had to replace any other remote in such a fashion. (computer mice yes, but not tv remotes)
