Channels didn't record Best Medicine episode
I have a Season Pass configured to record all episodes of this program. It has been recording fine and is set to record E08 but E07 wasn't recorded this week. When I searched the logs I didn't find anything about E07 at all.
We also had similar issues with other FOX shows like Kitchen Confidential. That issue was it says it recorded the show but when we played it it was a recording on some other random channel. We fixed that by locking all the FOX Season Passes to the local FOX station.
One of the more likely reasons for this is that the guide data failed to include the New tag for that specific episode. The only solutions I can suggest:
  • Change your pass to record all episodes (and, maybe, restrict it to the channel where you record your new episodes). You probably won't get too many dups.
  • Check once a week or so to be sure all of your most-valued shows will record.
My wife watches this show, and I have a season pass set up for it. There is no recording out there for it, nor it is in the trash. Apparently it was more than one station with a guide problem (unless your local Fox station is also WHNS).
I’m in Phoenix so different FOX. We’ve only had this issue with FOX shows. I modified the pass to record all and locked all passes on FOX to the correct station. Hopefully that will solve it. I also have SlingTV with Air but I can’t stand the picture quality. I will add all the FOX shows there as well as backup.
I had to record this episode manually as the guide data just listed "to be announced" for Best Medicine as well as Doc that aired after it. This wasn't limited to Channels. I saw the same issue on multiple websites as well. For some reason the guide data was just never updated. I always recommend checking your upcoming schedule daily to make sure something's set to record, and set a manual recording if not.
I ended up finding it on Hulu, and got it for her from there. Fox needs to clean up their act on the guide.
