Hello - Hoping for some help here. Been having a recurring issue for the past several months where occasionally the DVR features in my AppleTV Channels app will disappear, and won't come back unless I restart the device. The last time it did this was perhaps a month ago, and it stopped happening for a while but now has returned.
As best I can tell the DVR service is still running correctly - this has actually occurred while a show was recording, but the recording itself was not affected and the server is still running on the mini-PC I have it installed on upstairs. I can't tell if it's only the tvOS app that's having the problem but that seems to be the case, to me anyway. I also had the server log open for a while and checked after noticing the DVR options disappeared again, and there were no corresponding entries during that time. The bonjour service is checked and running; I only have the DVR server installed on one device, which is connected to the AppleTV via ethernet; there have been no network issues I'm aware of; HDHR Quarto firmware, tvOS and PC versions are all on the latest version. Not sure what else to check but I can't seem to figure this one out.
Any help would be hugely appreciated - Thank you!
