Yesterday Channels DVR failed to record a scheduled program as it was trying to access HDHomeRun 10A2CCE9 using the wrong IP address of 192.168.0.68.
A few days ago we had a power outage late at night. After power was restored 2 of my 3 HDHomeRuns acquired new IP address. In this case 10A2CCE9 went from 192.168.0.68 to 192.168.0.146.
Bug 1: It would appear that Channels DVR did not send out a HDHomeRun discover request to verify that it was using the correct IP address for 10A2CCE9.
In trying to correct this I used the dashboard (port 8089) to try and get the right IP addresses assigned. I did a "scan network" this did not fix the IP addresses.
Bug 2: It would appear that "scan network" does not check the IP addresses returned by HDHomeRun discover with the ones it already has.
I had to go in and use "Add Source" > "HDHomeRun Device" for each tuner before it got corrected.
DVR server 2022.09.17.0215 on Synology DS1621+.
