I have a problems were my computer stops recording after 20 minutes of the computer goes idle. I have tried windowews 11 with powertoys keeping the computer awake indefently and I have tried ubuntu serverv 24.04.1 and it dosent make a difference the computer stops recording after 20 minutes of the computer going idle.
Do you see your machine actually sleep and are positive that is what is happening?
also did you wipe your OS and try Ubuntu Server? If you did and the same problem happened did you check the power setting in the BIOS? Ive set up Ubuntu server for Channels multiple times and never seen it let the machine sleep in any situation. Might be something else at play. Also have you checked the Channels logs to see what is going on when the problem happens?
I did a fresh install and I have the same problem. I also just set channels dvr up on my MInecraft ubuntu server which has been running flawessly for 6 months and its doing the same exact thing. So it cant be my computer. I submitted my logs hours ago but they didnt get back to me. I am going to let it run for 20 minutes and post the logs here.
If you submit the logs you have to open a ticket as well. But once you reproduce the issue posting the logs here will hopefully shed some light...
Here are the logs.
Blockquote s)
2024/12/20 14:56:41.224418 [DVR] Starting job 1734721200-ch24.2 Without a Trace on ch=[24.2]
2024/12/20 14:56:41.224418 [DVR] Waiting 3m18.7755814s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:56:41.224418 [DBG] Scheduling wake timer for scheduled recording in 1m48.7755814s
2024/12/20 14:56:51.231182 [ERR] Failed to start stream on channel 24.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:56:51.231182 [DVR] Error running job 1734721200-ch24.2 Without a Trace: could not start stream on channels=[24.2]: HDHomeRun: No Video Data
2024/12/20 14:56:51.243611 [DVR] Starting job 1734721200-ch4.4 Monk on ch=[4.4]
2024/12/20 14:56:51.243611 [DVR] Waiting 3m8.7563884s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:56:51.243611 [DBG] Scheduling wake timer for scheduled recording in 1m38.7563884s
2024/12/20 14:57:01.248336 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:57:01.248840 [DVR] Error running job 1734721200-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 14:57:05.132976 [DVR] Starting job 1734721200-ch11.2 Dateline on ch=[11.2]
2024/12/20 14:57:05.132976 [DVR] Waiting 2m54.8670235s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:57:05.132976 [DBG] Scheduling wake timer for scheduled recording in 1m24.8670235s
2024/12/20 14:57:15.137820 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:57:15.137820 [DVR] Error running job 1734721200-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 14:57:35.168021 [DVR] Starting job 1734721200-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 14:57:35.168021 [DVR] Waiting 2m24.8319781s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:57:35.168021 [DBG] Scheduling wake timer for scheduled recording in 54.8319781s
2024/12/20 14:57:45.173167 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:57:45.173167 [DVR] Error running job 1734721200-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 14:57:55.239269 [DVR] Starting job 1734721200-ch24.2 Without a Trace on ch=[24.2]
2024/12/20 14:57:55.239269 [DVR] Waiting 2m4.7607307s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:57:55.239269 [DBG] Scheduling wake timer for scheduled recording in 34.7607307s
2024/12/20 14:58:05.244855 [ERR] Failed to start stream on channel 24.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:58:05.244855 [DVR] Error running job 1734721200-ch24.2 Without a Trace: could not start stream on channels=[24.2]: HDHomeRun: No Video Data
2024/12/20 14:58:05.257232 [DVR] Starting job 1734721200-ch4.4 Monk on ch=[4.4]
2024/12/20 14:58:05.257232 [DVR] Waiting 1m54.7427679s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:58:15.260929 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:58:15.260929 [DVR] Error running job 1734721200-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 14:58:19.152353 [DVR] Starting job 1734721200-ch11.2 Dateline on ch=[11.2]
2024/12/20 14:58:19.152353 [DVR] Waiting 1m40.847647s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:58:29.157290 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:58:29.157290 [DVR] Error running job 1734721200-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 14:58:49.188229 [DVR] Starting job 1734721200-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 14:58:49.188229 [DVR] Waiting 1m10.8117707s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:58:59.191959 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:58:59.191959 [DVR] Error running job 1734721200-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 14:59:09.264353 [DVR] Starting job 1734721200-ch24.2 Without a Trace on ch=[24.2]
2024/12/20 14:59:09.264353 [DVR] Waiting 50.7356463s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:59:19.266253 [ERR] Failed to start stream on channel 24.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:59:19.266253 [DVR] Error running job 1734721200-ch24.2 Without a Trace: could not start stream on channels=[24.2]: HDHomeRun: No Video Data
2024/12/20 14:59:19.276040 [DVR] Starting job 1734721200-ch4.4 Monk on ch=[4.4]
2024/12/20 14:59:19.276040 [DVR] Waiting 40.7239591s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:59:29.287277 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:59:29.287277 [DVR] Error running job 1734721200-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 14:59:33.166604 [DVR] Starting job 1734721200-ch11.2 Dateline on ch=[11.2]
2024/12/20 14:59:33.166604 [DVR] Waiting 26.8333958s until next job 1734724800-ch11.2 Dateline
2024/12/20 14:59:43.181639 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 14:59:43.181639 [DVR] Error running job 1734721200-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:00:00.023420 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:00:10.026279 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:00:10.026279 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:00:10.027557 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:00:20.032775 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:00:20.032775 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:00:20.042114 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:00:20.042114 [DVR] Waiting 2h59m39.9578856s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:00:20.042114 [DBG] Scheduling wake timer for scheduled recording in 2h58m9.9578856s
2024/12/20 15:00:30.045794 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:00:30.045794 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:00:30.058061 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:00:40.062674 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:00:40.062674 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:00:40.072449 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:00:50.079172 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:00:50.079172 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:00:50.079172 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:00:50.079172 [DVR] Waiting 2h59m9.9208278s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:00:50.079172 [DBG] Scheduling wake timer for scheduled recording in 2h57m39.9208278s
2024/12/20 15:01:00.085597 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:00.085597 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:01:00.097263 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:01:10.101096 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:10.101096 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:01:10.111324 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:01:20.115954 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:20.115954 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:01:20.126179 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:01:20.126179 [DVR] Waiting 2h58m39.8738208s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:01:20.126179 [DBG] Scheduling wake timer for scheduled recording in 2h57m9.8738208s
2024/12/20 15:01:30.132658 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:30.132658 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:01:30.133955 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:01:40.140857 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:40.140857 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:01:40.142647 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:01:50.147767 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:01:50.147767 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:01:50.149616 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:01:50.149616 [DVR] Waiting 2h58m9.8503832s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:01:50.149616 [DBG] Scheduling wake timer for scheduled recording in 2h56m39.8503832s
2024/12/20 15:02:00.154616 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:00.154616 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:02:00.156366 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:02:10.162757 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:10.162757 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:02:10.164688 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:02:20.170027 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:20.170027 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:02:20.171643 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:02:20.171643 [DVR] Waiting 2h57m39.8283563s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:02:20.171643 [DBG] Scheduling wake timer for scheduled recording in 2h56m9.8283563s
2024/12/20 15:02:20.172147 [DVR] Waiting 2h57m39.8278525s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:02:20.172147 [DBG] Scheduling wake timer for scheduled recording in 2h56m9.8278525s
2024/12/20 15:02:30.177693 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:30.177693 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:02:30.178926 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:02:30.178926 [DVR] Waiting 2h57m29.8210736s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:02:30.178926 [DBG] Scheduling wake timer for scheduled recording in 2h55m59.8210736s
2024/12/20 15:02:40.185421 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:40.185421 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:02:40.186534 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:02:40.186534 [DVR] Waiting 2h57m19.8134651s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:02:40.186534 [DBG] Scheduling wake timer for scheduled recording in 2h55m49.8134651s
2024/12/20 15:02:50.204716 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:02:50.204716 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:02:50.205377 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:02:50.205377 [DVR] Waiting 2h57m9.7946226s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:02:50.205377 [DBG] Scheduling wake timer for scheduled recording in 2h55m39.7946226s
2024/12/20 15:03:00.208022 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:03:00.208022 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:03:12.190563 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:03:12.190563 [DVR] Waiting 2h56m47.809437s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:03:12.190563 [DBG] Scheduling wake timer for scheduled recording in 2h55m17.809437s
2024/12/20 15:03:22.195417 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:03:22.195417 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:03:22.211671 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:03:22.211671 [DVR] Waiting 2h56m37.7883285s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:03:22.211671 [DBG] Scheduling wake timer for scheduled recording in 2h55m7.7883285s
2024/12/20 15:03:32.215859 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:03:32.215859 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:03:32.224633 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:03:32.224633 [DVR] Waiting 2h56m27.7753666s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:03:32.224633 [DBG] Scheduling wake timer for scheduled recording in 2h54m57.7753666s
2024/12/20 15:03:42.230815 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:03:42.230815 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:04:26.219316 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:04:26.219316 [DVR] Waiting 2h55m33.7806831s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:04:26.219316 [DBG] Scheduling wake timer for scheduled recording in 2h54m3.7806831s
2024/12/20 15:04:36.223385 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:04:36.223385 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:04:36.231985 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:04:36.231985 [DVR] Waiting 2h55m23.768015s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:04:36.231985 [DBG] Scheduling wake timer for scheduled recording in 2h53m53.768015s
2024/12/20 15:04:46.235798 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:04:46.235798 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:04:46.245923 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:04:46.246632 [DVR] Waiting 2h55m13.7533673s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:04:46.246632 [DBG] Scheduling wake timer for scheduled recording in 2h53m43.7533673s
2024/12/20 15:04:56.260673 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:04:56.260673 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:05:40.238196 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:05:40.238196 [DVR] Waiting 2h54m19.7618036s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:05:40.238196 [DBG] Scheduling wake timer for scheduled recording in 2h52m49.7618036s
2024/12/20 15:05:50.242806 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:05:50.242806 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:05:50.245945 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:05:50.245945 [DVR] Waiting 2h54m9.7540549s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:05:50.245945 [DBG] Scheduling wake timer for scheduled recording in 2h52m39.7540549s
2024/12/20 15:06:00.249882 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:06:00.249882 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:06:00.266400 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:06:10.278421 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:06:10.278421 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:06:10.280162 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:06:10.280162 [DVR] Waiting 2h53m49.719838s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:06:10.280162 [DBG] Scheduling wake timer for scheduled recording in 2h52m19.719838s
2024/12/20 15:06:20.283222 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:06:20.283222 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:06:54.248793 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:06:54.248793 [DVR] Waiting 2h53m5.7512067s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:06:54.248793 [DBG] Scheduling wake timer for scheduled recording in 2h51m35.7512067s
2024/12/20 15:07:04.254408 [ERR] Failed to start stream on channel 11.2 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:07:04.254408 [DVR] Error running job 1734724800-ch11.2 Dateline: could not start stream on channels=[11.2]: HDHomeRun: No Video Data
2024/12/20 15:07:04.267436 [DVR] Waiting 2h52m55.732564s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:07:04.267436 [DBG] Scheduling wake timer for scheduled recording in 2h51m25.732564s
2024/12/20 15:07:14.287886 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:07:14.287886 [DVR] Waiting 2h52m45.7121135s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:07:14.287886 [DBG] Scheduling wake timer for scheduled recording in 2h51m15.7121135s
2024/12/20 15:07:24.293739 [ERR] Failed to start stream on channel 11.7 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:07:24.293739 [DVR] Error running job 1734724800-ch11.7 Cold Case Files: could not start stream on channels=[11.7]: HDHomeRun: No Video Data
2024/12/20 15:07:24.295056 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:07:24.295056 [DVR] Waiting 2h52m35.7049438s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:07:24.295056 [DBG] Scheduling wake timer for scheduled recording in 2h51m5.7049438s
2024/12/20 15:07:34.300443 [ERR] Failed to start stream on channel 4.4 via 10A75647: HDHomeRun: No Video Data
2024/12/20 15:07:34.300443 [DVR] Error running job 1734724800-ch4.4 Monk: could not start stream on channels=[4.4]: HDHomeRun: No Video Data
2024/12/20 15:08:08.259532 [DVR] Starting job 1734724800-ch11.2 Dateline on ch=[11.2]
2024/12/20 15:08:08.259532 [DVR] Waiting 2h51m51.7404676s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:08:08.259532 [DBG] Scheduling wake timer for scheduled recording in 2h50m21.7404676s
2024/12/20 15:08:08.711122 [TNR] Opened connection to 10A75647/2 for ch11.2 Crime
2024/12/20 15:08:08.711122 [DVR] Recording for job 1734724800-ch11.2 from 10A75647 ch11.2 into "TV\Dateline\Dateline S04E67 2020-12-08 Before Dawn 2024-12-20-1508.mpg" for 1h51m51.7404676s
2024/12/20 15:08:08.783757 [IDX] Generating video index for job 1734724800-ch11.2
2024/12/20 15:08:28.302647 [DVR] Starting job 1734724800-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 15:08:28.302647 [DVR] Waiting 2h51m31.6973527s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:08:28.302647 [DBG] Scheduling wake timer for scheduled recording in 2h50m1.6973527s
2024/12/20 15:08:28.689550 [TNR] Opened connection to 10A75647/3 for ch11.7 NEST
2024/12/20 15:08:28.690065 [DVR] Recording for job 1734724800-ch11.7 from 10A75647 ch11.7 into "TV\Cold Case Files\Cold Case Files S01E07 1999-02-12 One Night on the Bayou Th 2024-12-20-1508.mpg" for 51m31.6973527s
2024/12/20 15:08:28.752484 [IDX] Generating video index for job 1734724800-ch11.7
2024/12/20 15:08:38.315519 [DVR] Starting job 1734724800-ch4.4 Monk on ch=[4.4]
2024/12/20 15:08:38.315519 [DVR] Waiting 2h51m21.6844804s until next job 1734735600-ch104.1 Local 4 News at 6
2024/12/20 15:08:38.315519 [DBG] Scheduling wake timer for scheduled recording in 2h49m51.6844804s
2024/12/20 15:08:38.793684 [TNR] Opened connection to 10A75647/0 for ch4.4 COZI
2024/12/20 15:08:38.793684 [DVR] Recording for job 1734724800-ch4.4 from 10A75647 ch4.4 into "TV\Monk\Monk S03E02 2004-06-25 Mr Monk the Panic Room 2024-12-20-1508.mpg" for 51m21.6844804s
2024/12/20 15:08:38.858886 [IDX] Generating video index for job 1734724800-ch4.4
2024/12/20 15:10:04.827012 [TRS] DNS: OK: Resolved host via system DNS
2024/12/20 15:10:04.827012 [TRS] DBG: Provider: "Comcast Cable Communications, LLC" (CCCS) from 96.96.111.9
2024/12/20 15:10:05.188039 [TRS] Cloud Reachable: OK: Connected to community.getchannels.com
2024/12/20 15:10:05.283907 [TRS] Local Time: OK: Local clock is accurate
2024/12/20 15:10:05.734696 [TRS] TV Everywhere: OK: Chrome version up to date: 131.0.0.0
2024/12/20 15:10:05.747241 [TRS] TV Everywhere DNS: OK: Resolved TVE authenticator via system DNS
2024/12/20 15:10:05.759641 [TRS] ad-dns: Resolved adservice.google.com: 142.250.191.162
2024/12/20 15:10:05.770837 [TRS] ad-dns: Resolved googleads.g.doubleclick.net: 142.250.191.130
2024/12/20 15:10:05.782838 [TRS] ad-dns: Resolved assets.adobedtm.com: 23.201.60.236
2024/12/20 15:10:05.794085 [TRS] ad-dns: Resolved d.adroll.com: 52.201.148.76, 3.231.252.60
2024/12/20 15:10:05.817661 [TRS] ad-dns: Resolved bat.bing.com: 150.171.28.10, 150.171.27.10
2024/12/20 15:10:05.828304 [TRS] ad-dns: Resolved pubads.g.doubleclick.net: 142.250.190.130
2024/12/20 15:10:05.838639 [TRS] ad-dns: Resolved edge.api.brightcove.com: 146.75.10.27
2024/12/20 15:10:05.849762 [TRS] ad-dns: Resolved medium.ngtv.io: 23.61.108.204
2024/12/20 15:10:05.849762 [TRS] DNS Ad Blocking: OK
2024/12/20 15:10:06.108459 [TRS] Guide Provider: OK: Connected to guide provider
2024/12/20 15:10:06.411111 [TRS] Device Lineups: OK: All devices have guide data mapped
2024/12/20 15:10:06.411111 [TRS] Operating System: OK
2024/12/20 15:10:06.437249 [TRS] Network Interfaces: OK
2024/12/20 15:10:06.729113 [TRS] Remote Access: OK: Successfully established external connection
2024/12/20 15:10:06.729113 [TRS] Recording Directory: OK
2024/12/20 15:10:06.731745 [TRS] Disk Permissions: OK
2024/12/20 15:10:06.731745 [TRS] Disk Space: OK: DVR directory 'D:\Channels DVR' has 894.9G free
2024/12/20 15:10:06.878112 [TRS] DVR Version: OK: DVR is up to date
2024/12/20 15:10:06.878112 [TRS] DBG: Version info: &{2024.12.10.0055 https://cdn.channelsdvr.net/dvr false}
2024/12/20 15:10:06.878112 [TRS] DVR Status: OK: DVR is enabled
2024/12/20 15:10:07.224278 [TRS] System Firewall: OK
2024/12/20 15:10:07.233791 [TRS] Third Party Firewall: OK
2024/12/20 15:10:07.233791 [TRS] Network Flow Control: OK
2024/12/20 15:10:07.300652 [TRS] Power Management: OK
Blockquote
I had to shorten the logs because they were a mile long. And I really apricate your help this has been driving me crazy for days now. ANd the crazy part about all of this is if I use my firestick to open the guide everythiing works. It starts recording and all of my tv show will record until I let it idle for 20 minutes.
Can you use the HDHomeRun software to view those Channels ? You might have a HDHomeRun unit failing.
Yes I can view the channels with the HD homerun software. And the unit its self is only 8 days old. And as long as I am on my computer it will work all day long. But 20 minutes after the computer goes idle it stops recording and it did the same thing on my minecraft server. I stopped watching tv and went to the store and it stopped recording.
Your Channels DVR server needs to be on 24x7x365.
Set the power management so it doesn't sleep/suspend.
Okay to have it blank the monitor, but don't sleep the cpu/gpu/bus/pci/usb/drives
Here are the logs I found when the recording failed.
2024/12/20 13:00:00.002676 [TNR] Closed connection to 10A75647/2 for ch11.2 Crime
2024/12/20 13:00:00.003188 [TNR] Closed connection to 10A75647/3 for ch11.7 NEST
2024/12/20 13:00:00.006198 [TNR] Closed connection to 10A75647/0 for ch24.2 Charge!
2024/12/20 13:00:00.034217 [SNR] Signal statistics for "TV\Dateline\Dateline S01E61 2017-12-19 Frantic 2024-12-20-1251.mpg": ss=81%,80%-82% snq=47%-48% seq=26%,0%-85% bps=1280085,476768-2147712 pps=123,52-192 sigerr=100%
2024/12/20 13:00:00.048417 [SNR] Signal statistics for "TV\Cold Case Files\Cold Case Files S01E04 1999-01-23 The Answer in the Box Mat 2024-12-20-1251.mpg": ss=81%-82% snq=47%-48% seq=27%,0%-85% bps=1351573,658752-2147712 pps=128,69-192 sigerr=100%
2024/12/20 13:00:00.056399 [SNR] Signal statistics for "TV\Without a Trace\Without a Trace S02E12 2004-01-15 Hawks and Handsaws 2024-12-20-1252.mpg": ss=66%-67% snq=49%,48%-50% seq=100% bps=2344515,138368-5829504 pps=208,13-499
2024/12/20 13:00:00.056399 [SNR] Buffer statistics for "TV\Dateline\Dateline S01E61 2017-12-19 Frantic 2024-12-20-1251.mpg": buf=0% drop=0%
2024/12/20 13:00:00.069818 [DVR] Finished job 1734714000-ch11.2 Dateline
2024/12/20 13:00:00.073436 [SNR] Buffer statistics for "TV\Cold Case Files\Cold Case Files S01E04 1999-01-23 The Answer in the Box Mat 2024-12-20-1251.mpg": buf=0% drop=0%
2024/12/20 13:00:00.077930 [DVR] Finished job 1734714000-ch11.7 Cold Case Files
2024/12/20 13:00:00.085235 [SNR] Buffer statistics for "TV\Without a Trace\Without a Trace S02E12 2004-01-15 Hawks and Handsaws 2024-12-20-1252.mpg": buf=0% drop=0%
2024/12/20 13:00:00.097898 [DVR] Finished job 1734714000-ch24.2 Without a Trace
2024/12/20 13:00:00.111287 [DVR] Processing file-57: TV\Dateline\Dateline S01E61 2017-12-19 Frantic 2024-12-20-1251.mpg
2024/12/20 13:00:00.236767 [DVR] Running commercial detection on file 57 (TV\Dateline\Dateline S01E61 2017-12-19 Frantic 2024-12-20-1251.mpg)
2024/12/20 13:00:00.238276 [DVR] Processing file-59: TV\Without a Trace\Without a Trace S02E12 2004-01-15 Hawks and Handsaws 2024-12-20-1252.mpg
2024/12/20 13:00:00.387220 [DVR] Processing file-58: TV\Cold Case Files\Cold Case Files S01E04 1999-01-23 The Answer in the Box Mat 2024-12-20-1251.mpg
2024/12/20 13:00:00.767371 [TNR] Opened connection to 10A75647/2 for ch11.2 Crime
2024/12/20 13:00:00.767876 [DVR] Recording for job 1734717600-ch11.2 from 10A75647 ch11.2 into "TV\Dateline\Dateline S01E63 2017-12-21 Nightfall 2024-12-20-1300.mpg" for 59m59.9988668s
2024/12/20 13:00:00.767876 [DVR] Starting job 1734717600-ch11.7 Cold Case Files on ch=[11.7]
2024/12/20 13:00:00.849988 [IDX] Generating video index for job 1734717600-ch11.2
2024/12/20 13:00:01.669718 [TNR] Opened connection to 10A75647/3 for ch11.7 NEST
2024/12/20 13:00:01.670272 [DVR] Recording for job 1734717600-ch11.7 from 10A75647 ch11.7 into "TV\Cold Case Files\Cold Case Files S01E05 1999-01-29 The Hunter Homicides The 2024-12-20-1300.mpg" for 59m59.2321239s
2024/12/20 13:00:01.670272 [DVR] Starting job 1734717600-ch24.2 Without a Trace on ch=[24.2]
2024/12/20 13:00:01.768848 [IDX] Generating video index for job 1734717600-ch11.7
2024/12/20 13:00:02.105923 [TNR] Opened connection to 10A75647/0 for ch24.2 Charge!
2024/12/20 13:00:02.106432 [DVR] Recording for job 1734717600-ch24.2 from 10A75647 ch24.2 into "TV\Without a Trace\Without a Trace S02E13 2004-01-29 Life Rules 2024-12-20-1300.mpg" for 59m58.3297279s
2024/12/20 13:00:02.106432 [DVR] Starting job 1734717600-ch4.4 Monk on ch=[4.4]
2024/12/20 13:00:02.106432 [DVR] Waiting 59m57.8935677s until next job 1734721200-ch11.2 Dateline
2024/12/20 13:00:02.106432 [DBG] Scheduling wake timer for scheduled recording in 58m27.8935677s
2024/12/20 13:00:02.106970 [DVR] Waiting 59m57.89303s until next job 1734721200-ch11.2 Dateline
2024/12/20 13:00:02.106970 [DBG] Scheduling wake timer for scheduled recording in 58m27.89303s
2024/12/20 13:00:02.186853 [IDX] Generating video index for job 1734717600-ch24.2
2024/12/20 13:00:02.661607 [TNR] Opened connection to 10A75647/1 for ch4.4 COZI
2024/12/20 13:00:02.662116 [DVR] Recording for job 1734717600-ch4.4 from 10A75647 ch4.4 into "TV\Monk\Monk S03E01 2004-06-18 Mr Monk Takes Manhattan 2024-12-20-1300.mpg" for 59m57.8935677s
2024/12/20 13:00:02.696910 [DVR] Refreshing metadata for Monk (184807)
2024/12/20 13:00:03.507292 [IDX] Generating video index for job 1734717600-ch4.4
2024/12/20 13:00:28.665816 [DVR] Commercial detection for Dateline S01E61 2017-12-19 Frantic 2024-12-20-1251.mpg finished with 4 markers in 28.4290493s.
2024/12/20 13:00:28.724847 [DVR] Running commercial detection on file 58 (TV\Cold Case Files\Cold Case Files S01E04 1999-01-23 The Answer in the Box Mat 2024-12-20-1251.mpg)
2024/12/20 13:00:51.603684 [DVR] Commercial detection for Cold Case Files S01E04 1999-01-23 The Answer in the Box Mat 2024-12-20-1251.mpg finished with 2 markers in 22.8788373s.
2024/12/20 13:00:51.672667 [DVR] Running commercial detection on file 59 (TV\Without a Trace\Without a Trace S02E12 2004-01-15 Hawks and Handsaws 2024-12-20-1252.mpg)
2024/12/20 13:01:02.499227 [DVR] Commercial detection for Without a Trace S02E12 2004-01-15 Hawks and Handsaws 2024-12-20-1252.mpg finished with 4 markers in 10.8270815s.
2024/12/20 13:05:34.546562 [TNR] Closing connection 10A75647/0 ch24.2 after no data was received for 6s
2024/12/20 13:05:34.553996 [TNR] Closing connection 10A75647/1 ch4.4 after no data was received for 6s
2024/12/20 13:05:34.555030 [TNR] Closed connection to 10A75647/0 for ch24.2 Charge!
2024/12/20 13:05:34.555552 [TNR] Closing connection 10A75647/2 ch11.2 after no data was received for 6s
2024/12/20 13:05:34.562190 [TNR] Closing connection 10A75647/3 ch11.7 after no data was received for 6s
2024/12/20 13:05:34.564416 [TNR] Closed connection to 10A75647/1 for ch4.4 COZI
2024/12/20 13:05:34.578487 [TNR] Closed connection to 10A75647/3 for ch11.7 NEST
2024/12/20 13:05:34.579567 [TNR] Closed connection to 10A75647/2 for ch11.2 Crime
2024/12/20 13:05:34.583867 [SNR] Signal statistics for "TV\Without a Trace\Without a Trace S02E13 2004-01-29 Life Rules 2024-12-20-1300.mpg": ss=68%,26%-75% snq=48%,0%-50% seq=98%,0%-100% bps=3091517,0-5707680 pps=268,0-489 sigerr=1%
2024/12/20 13:05:34.606250 [SNR] Signal statistics for "TV\Monk\Monk S03E01 2004-06-18 Mr Monk Takes Manhattan 2024-12-20-1300.mpg": ss=79%,41%-83% snq=57%,0%-63% seq=97%,0%-100% bps=3177049,0-4978240 pps=275,0-426 sigerr=3%
2024/12/20 13:05:34.606250 [SNR] Signal statistics for "TV\Cold Case Files\Cold Case Files S01E05 1999-01-29 The Hunter Homicides The 2024-12-20-1300.mpg": ss=79%,39%-81% snq=46%,0%-47% seq=2%,0%-37% bps=1261418,0-2146208 pps=121,0-192 sigerr=100%
2024/12/20 13:05:34.621369 [SNR] Signal statistics for "TV\Dateline\Dateline S01E63 2017-12-21 Nightfall 2024-12-20-1300.mpg": ss=79%,38%-81% snq=46%,0%-47% seq=2%,0%-39% bps=1509300,0-2146208 pps=140,0-195 sigerr=100%
2024/12/20 13:05:34.621369 [SNR] Buffer statistics for "TV\Without a Trace\Without a Trace S02E13 2004-01-29 Life Rules 2024-12-20-1300.mpg": buf=0% drop=0%
2024/12/20 13:05:34.630392 [DVR] Job 1734717600-ch24.2 Without a Trace ended prematurely: 54m25.3696075s
2024/12/20 13:05:34.633955 [SNR] Buffer statistics for "TV\Monk\Monk S03E01 2004-06-18 Mr Monk Takes Manhattan 2024-12-20-1300.mpg": buf=0% drop=0%
2024/12/20 13:05:34.634754 [SNR] Buffer statistics for "TV\Cold Case Files\Cold Case Files S01E05 1999-01-29 The Hunter Homicides The 2024-12-20-1300.mpg": buf=0% drop=0%
2024/12/20 13:05:34.643755 [SNR] Buffer statistics for "TV\Dateline\Dateline S01E63 2017-12-21 Nightfall 2024-12-20-1300.mpg": buf=0% drop=0%
2024/12/20 13:05:34.645946 [DVR] Job 1734717600-ch11.7 Cold Case Files ended prematurely: 54m25.354054s
The Signal Quality (snq) on your channels is really bad.
You may need to re-aim or replace your antenna.
ss 60% (-24dBmV) minimum
Signal Strength 100% = 0dBmV = -48.75dBm and a change of 5% is a 3dBmV difference, so every 1% change is equivilent to 0.6dBmV. A signal strength of 80% (-12dBmV) or higher is recommended for OTA operation, 60% (-24dBmV) minimum. OTA ATSC minimum -30dBmV (50%)
snq 50% (16dB SNR) minimum
Signal Quality is scaled for each modulation type such that 50% is the minimum signal-to-noise requirement. For ATSC1, 100% SNQ is 30dB+ SNR, 50% is 16dB SNR.
seq 100%
Symbol Quality is an indication of how many uncorrectable TS frames (packets coming out of the demodulator with the TEI-Transport Error Indicated bit set in the packet header) have been lost in the last second (logarithmic scale). The Symbol Quality needs to be 100%.
Tuner signal or firmware issue probably
Why does it record all day long while I am watching TV? It only stops recoording if I stop watching TV and the computer goes idle? Yesterday I recorded for 10hrs without a problem. But as soon as I quit watching TV it recording stopped about 20 minutes later.
And like I say if I start watching TV the channels come in clear and I don't have any recording problems.
Indoor antenna?
Maybe your position relative to an indoor antenna affects the reception?
It's an indoor antenna and I sit in the same seat when it stops recording after the computer goes idle. And like i say the signal will not drop on any channels as long as I am watching TV.
Thats the part that confuses me. If the position of the antenna was bad or if it was a bad antenna it wouldn't come in at all if I was watching.
If you look at the signal stats that Channels DVR logged from your HDHR tuner, it shows your Signal Quality is too low, most likely causing the issue.
You can ask the experts for help in the SiliconDust forum HDHomeRun Hardware Setup & Troubleshooting - Silicondust
I have a silicon dust lte filter on my antenna. I just took that off and I am going to wait 20 minutes to see if it drops again. And if it does ill replace the antenna with my spare antenna. And report back.
You may also be dealing with 2 seperate problems.
On the antenna unless the lte filter is bad its doubtful it will change anything. Replacing your antenna may not make a difference either. It is probably an issue with signal/antenna placement espacially if it is an indoor antenna.
Can you describe exactly what happens when you notice the problem?
If I am watching TV (DVR Recordings) all of my channels come in with no problems. If I stop wattching TV the DVR stops recording after 20 minutes or so. But if I let it stop and start watching TV on my firestick It will instantly start recorrdinng again and have no more problems until I stop watching TV again/ And thats the part I dont understand. Wouldn't it not work if I was watching TV and the placement was bad? And why does it stop working if I am not watching tv?
Ahhh ok so the computer being idle likely has nothing to do with it. Sounds like when you are recording your stream is so bad that dies after a while and then maybe when you retune the channel it kick starts the recording again. Either way your signal issue needs to be sorted so get that corrected and then do some more testing.
