Channels DVR System Tray Icon Keeps Disappearing. Keeps happening on stable release and pre-release.
Anyone else seeing this on Windows?
No, not on Windows 7.
How do you relaunch it without having to reboot? Recording and viewing still function with no issues.
Are you sure its not being hidden under the expand button that shows all the system tray icons?
I am 100% sure. I have that icon set to appear along with a few others. It's not hidden in anyway.
I have found out the issue. It has to do with DisplayFusion managing the task bar on a 2nd screen. Disabling taskbar management from Display Fusion fixed the issue because other icons were starting to disappear also.
