I have a mac mini that had a system drive failure. I cloned my drive with Carbon Copy. I had to disconnect my DVR drive to run CC to a new drive. Once booting back up and connecting my DVR drive the Channels DVR service does not start, nor can I hit the service from the web browser. If I try and manually start it I'm getting some type of error.
There is nothing in the latest folder, so I'm having to run from a previous version
/Users/admin/channels-dvr/2021.03.30.0356/channels-dvr ; exit;
Mac-mini:~ admin$ /Users/admin/channels-dvr/2021.03.30.0356/channels-dvr ; exit;
2021/06/23 11:40:21.732250 [SYS] Starting Channels DVR v2021.03.30.0356 (darwin-x86_64 pid:74974) in /Users/admin
2021/06/23 11:40:21.756913 [SYS] Started HTTP Server
2021/06/23 11:40:22.232442 [HDR] Found 1 devices
2021/06/23 11:40:22.279230 [ERR] Failed to refresh auth: missing oauth client
2021/06/23 11:40:22.501460 [SYS] Downloading new version v2021.05.26.1807
2021/06/23 11:40:23.019797 [SYS] Bonjour service registered with Mac-mini.local
2021/06/23 11:40:26.543902 [SYS] Update downloaded and verified successfully.
2021/06/23 11:40:26.543923 [SYS] Shutting down for upgrade from v2021.03.30.0356 to v2021.05.26.1807
2021/06/23 11:40:26.544098 [SYS] Bonjour service stopped.
2021/06/23 11:40:27.545280 [SYS] Goodbye.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Log file never gets written to since the clone/reboot last night
goroutine 54 [IO wait]:
internal/poll.runtime_pollWait(0xf200a00, 0x72, 0x56fc700)
runtime/netpoll.go:222 +0x55
internal/poll.(*pollDesc).wait(0xc000728518, 0x72, 0x56fc700, 0x60a5fa0, 0x0)
internal/poll/fd_poll_runtime.go:87 +0x45
internal/poll.(*pollDesc).waitRead(...)
internal/poll/fd_poll_runtime.go:92
internal/poll.(*FD).Read(0xc000728500, 0xc001432000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
internal/poll/fd_unix.go:159 +0x1a5
net.(*netFD).Read(0xc000728500, 0xc001432000, 0x1000, 0x1000, 0xb9b66c384ef, 0x0, 0x55388b8)
net/fd_posix.go:55 +0x4f
net.(*conn).Read(0xc00142a000, 0xc001432000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
net/net.go:182 +0x8e
github.com/soheilhy/cmux.(*bufferedReader).Read(0xc00142c010, 0xc001432000, 0x1000, 0x1000, 0xc000728500, 0x0, 0xc000e460c8)
github.com/soheilhy/[email protected]/buffer.go:53 +0x12d
github.com/soheilhy/cmux.(*MuxConn).Read(0xc00142c000, 0xc001432000, 0x1000, 0x1000, 0xc000728500, 0x5537228, 0xc001443bd0)
github.com/soheilhy/[email protected]/cmux.go:259 +0x4f
net/http.(*connReader).Read(0xc000e460c0, 0xc001432000, 0x1000, 0x1000, 0xc001443c10, 0x4f7777a, 0xc00142a000)
net/http/server.go:798 +0x1ad
bufio.(*Reader).fill(0xc00106e120)
bufio/bufio.go:101 +0x105
bufio.(*Reader).Peek(0xc00106e120, 0x4, 0x9d4ca08428d, 0x6785880, 0x0, 0x0, 0x6785880)
bufio/bufio.go:139 +0x4f
net/http.(*conn).serve(0xc000b334a0, 0x571c740, 0xc00142e000)
net/http/server.go:1950 +0xa14
created by net/http.(*Server).Serve
net/http/server.go:2969 +0x36c
2021/06/22 23:13:17.607502 [SYS] Starting Channels DVR v2021.05.26.1807 (darwin-x86_64 pid:1592) in /Users/admin/channels-dvr/data
2021/06/22 23:13:17.633997 [SYS] Started HTTP Server
2021/06/22 23:13:18.045064 [HDR] Found 0 devices
2021/06/22 23:13:18.113356 [ERR] Failed to refresh auth: Post "https://community.getchannels.com/dvr/api": dial tcp: lookup community.getchannels.com: no such host
2021/06/22 23:13:18.172946 [DVR] Recording engine started in /Volumes/DVR
2021/06/22 23:13:18.176158 [NAT] Failed to discover gateway: no gateway found
2021/06/22 23:13:18.176211 [SYS] Error checking for update: Get "https://channels-dvr.s3.amazonaws.com/latest.json": dial tcp: lookup channels-dvr.s3.amazonaws.com: no such host
2021/06/22 23:13:18.177506 [DVR] Waiting 14h45m41.822502s until next job 1624474740-58 The Chase
2021/06/22 23:13:18.977215 [SYS] Bonjour service registered with Mac-mini.local
2021/06/22 23:13:19.060454 [ERR] Could not create backup: stat /Volumes/DVR: no such file or directory
2021/06/22 23:13:24.245792 [NAT] Failed to discover upnp routers
2021/06/22 23:13:24.245833 [NAT] Failed to discover router using natpmp and upnp.
2021/06/22 23:18:18.400807 [ERR] Could not create backup: stat /Volumes/DVR: no such file or directory
2021/06/22 23:23:18.442004 [ERR] Could not create backup: stat /Volumes/DVR: no such file or directory
If I try to reinstall Channels DVR I get...
Starting Installer...
Fetching latest version number...
Channels DVR is already installed! All done.
