My cable provider is Comcast. A few weeks ago I noticed that the TV OS Channels app started freezing up and showing pixelation (along with chopped sound) when streaming from the HDHomeRun Prime.
HDHomeRun Prime is running 20170930 firmware. I rescanned the channel via the HDHomeRun Prime’s web page and noticed that most HD channels are now listed as AVC HD.
This may or may not have coincided with upgrading the firmware on the HDHomeRun Prime to 20170930 (which happens automatically once the Silicon Dust’s macOS app is installed). This issue did not occur since April of 2017. Before April 2017, I had all sorts of issues with the HDHomeRun dropping off the network and having to be power-cycled. This was happening for a year until Silicon Dust finally figured out the issue and fixed it in the beta firmware in April of 2017. Then, Silicon Dust released the final firmware with the fix in the summer of 2017, which worked fine in my environment. However, the code 20170930 is having issues. I’m not sure if this is due to the code or if this is due to Comcast encoding with AVC the HD channels now. All HD Channels used to be encoded with MPEG 2, but now most of them are encoded with AVC (which I suspect is MPEG 4/H.264).
Any suggestions?
