I wonder if the "Sync Station Mapping" option would be helpful, too.
This has happened to me on at least 3 occasions. The fix that worked for me was to remove the provider and then add it back.
silly question but who is the provider? Not that you would know MY provider, but where do I find that info?
Looking at the screenshot of your guide, it looks like your source is an over-the-air antenna. In the WebUI if you click on "Manage Lineup" for your source, in the upper left-hand corner of the resulting page you should see a line like "DVR: USA-OTA". This is what Gracenote uses to provide the proper guide data for your source.
well folks, thanks! It's back to normal! I'm not sure what did it since the change did not happen immediately, but it was probably deleting and adding the provider.
Happy holidays!
