Channels so far has been wonderful, so I am moving from my testing phase of using Channels DVR and moving to a more permanent location. I have been testing on a raspberry pi 4, but I wish to move Channels DVR to my NAS server since it has substantially more space.
I could install directly on the CentOS 8 NAS server, but since I am not the most tech savvy of people and all I do is a bit of maintenance, I rather not necessarily install it directly in case something breaks. Also, channels install seems to require sudo privileges which concerns me a little bit (but this is just my ignorance).
I wonder if anyone here has Channels DVR installed and uses some form of Virtual Machine like VMware workstation or a vm under Virt manager (which uses qemu / kvm to virtualize)? Would there be any reason to not use a virtual machine?
The alternative is Docker, but I do not have much experience using Docker, and @tmm1 (A Channels Developer) mentioned Docker was not recommended in an earlier post. Though that was some years ago. Is that still the case?
What does the community think? Would going on the vm root be fine, or I should use linux installer or docker?
