Channels IPTV links
This is the full log
2020/05/18 16:20:48.900939 [TNR] Opened connection to TVE-ATTOTT for ch6051 CNBC
2020/05/18 16:20:48.903413 [HLS] Starting transcoder for channel 6051 from 192.168.1.231 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/05/18 16:20:49.831626 [HLS] Probed live stream in 927.715312ms: h264 1920x1080 progressive 4202567bps
2020/05/18 16:20:49.975594 [HLS] Session ch6051-dTVE-ATTOTT-ip192.168.1.231 started in 1.341794374s
2020/05/18 16:24:24.020489 [HLS] Stopping inactive session ch6051-dTVE-ATTOTT-ip192.168.1.231
2020/05/18 16:24:24.020596 [HLS] Stopping transcoder session ch6051-dTVE-ATTOTT-ip192.168.1.231 (out: 3m50.029011s, finished: false)
2020/05/18 16:24:24.124703 [TNR] Closed connection to TVE-ATTOTT for ch6051 CNBC
When i surf channels from app i see only these lines of log with no remux anywhere.
2020/05/18 15:43:52.739183 [TVE] stream timestamps: ahc: start_at=2020-05-18T15:43:55-04:00 current_at=2020-05-18T15:44:16-04:00 end_at=2020-05-18T15:44:24-04:00
2020/05/18 15:43:52.739285 [TNR] Opened connection to TVE-ATTOTT for ch6111 AHC
2020/05/18 15:47:15.699535 [TNR] Closed connection to TVE-ATTOTT for ch6111 AHC
What parameters i need to pass in m3u8 link to get the above with just [TVE] stream timestamps:?
Maybe you still have "Old transcoder" enabled on your DVR?
The logs are not showing transcoding, only remuxing. Remuxing is required to turn mpegts stream into an hls stream.
Here are my settings.
How is this happening?
The app doesn't use HLS. Remux is required for HLS only.
Can you please share the url that gets played in the app?
stream.mpg url was discussed in Streams URL
Thanks. I thought there is different url.
