Channels not creating guide from XML link
I've set up an M3U source and configured it with the link to the XML guide provided to me, however Channels doesn't index the guide data nor does it add channel logos. The same URL works in Emby properly, but for some reason doesn't in Channels. Can anyone point me in the direction to resolve this issue? Thank you.
Possible that CDvR is “stricter” with its XML tags?
You could try that source through a Threadfin container to attempt to normalize its output.
