Channels on Shield keeps losing OTA channels
Two mornings in a row my HDHR has had "0" channels when I loaded up Channels (and due to this, recordings fail).
When I go to MANAGE SOURCES the HDHR is there, when I scan for channels if finds them all and they appear again on the guide. But I have to manually go back in each morning and scan. Any thoughts on what might be happening or what log I should look at?
Are you seeing this in the web ui or a client of some kind?
Do you have an DHCP reserved IP address set for your HDHR in your router?
Maybe the HDHR is getting different IP addresses?
Running the DVR and Client on my Nvidia Shield Pro
I do, and the 192.x.x.x. IP doesn't change over night, but the channels disappear.
Anything showing up in the hdhr logs?
http://hdhomerun.local/log.html
Turns out this was a VPN issue.
