I recently got a DS1621+ and installed Channels on it. It was working fine, but within the last few days or so, I noticed it was no longer working from a client. I took a look today and found that it is actually running. The web interface is up, and I can see recordings listed. It doesn't see my tuner (I suspect I didn't plug it in when I recently moved a switch).
When I try to connect from a client, it doesn't seem to automatically discover it. I put in the IP of the NAS and the client just goes "Connecting", then "Scanning for sources". If I put in an IP not running Channels, I get the message "Channels DVR Server was not found at" that IP. When I looked in the web interface for clients, I see my clients showing recently connected ("now" for my iPhone), but it doesn't work. So, the server is seeing my clients. Is this failing just because it can't find a tuner? Or is there something else wrong?
I'm running DSM 7.1-42661 Update 1.
