Channels Panic?
So I noticed shows from yesterday were not showing up to watch. The DVR says they ate queued - from yesterday?? Seems odd... Maybe I’ll look in the log..
Seeing the word “Panic” is not instilling me with a sense of confidence! My Channels server is running on an old mac laptop, and has been running flawlessly for many months, until now. Time to panic? Like all things I.T. maybe I will try to turn it off and on.
2021/01/26 20:19:29 [Recovery] 2021/01/26 - 20:19:29 panic recovered:
176838 bytes still won't fit in the cache! (max 10485760 bytes)
io/ioutil/ioutil.go:30 (0x423c4a5)
runtime/panic.go:969 (0x403a718)
github.com/peterbourgon/diskv/[email protected]/diskv.go:713 (0x464762c)
github.com/peterbourgon/diskv/[email protected]/diskv.go:634 (0x4646c3b)
github.com/peterbourgon/diskv/[email protected]/diskv.go:652 (0x4646ef8)
github.com/peterbourgon/diskv/[email protected]/diskv.go:473 (0x4645f2e)
bytes/buffer.go:204 (0x408b250)
io/ioutil/ioutil.go:36 (0x423ae64)
io/ioutil/ioutil.go:45 (0x46453b0)
github.com/peterbourgon/diskv/[email protected]/diskv.go:344 (0x4645376)
github.com/fancybits/channels-server/httpcache/disk_cache.go:31 (0x4648da8)
github.com/gregjones/[email protected]/httpcache.go:53 (0x463fdde)
github.com/gregjones/[email protected]/httpcache.go:144 (0x4640392)
github.com/fancybits/channels-server/httpcache/cache.go:78 (0x4648597)
net/http/httputil/reverseproxy.go:288 (0x43b7914)
github.com/fancybits/channels-server/http_tms.go:149 (0x4f5d91c)
github.com/gin-gonic/[email protected]/context.go:165 (0x461809a)
github.com/fancybits/channels-server/http.go:234 (0x4effd6b)
github.com/fancybits/channels-server/http.go:214 (0x4eff952)
github.com/fancybits/channels-server/http.go:206 (0x4efeb14)
github.com/gin-gonic/[email protected]/recovery.go:106 (0x462c2e8)
github.com/gin-gonic/[email protected]/logger.go:241 (0x462b404)
Update your dvr to the latest prerelease
It had been a couple months since restarting my mac containing the server. After restart, channnels seems to be working normally. However, I missed recording several shows, It would be good if you would issue a warning message at the top of the library page that the dvr may not be recording normally.
This panic should not have been impacting your recordings. If you were having issues with recordings it’s a separate issue we’ll need to investigate further.
I am not sure what to say, restarting seems to have solved it. The old mac laptop was running for months and probably needed to be rebooted anyhow.
I have seen unix systems issue a panic when there is insufficient virtual memory space. Given the long time it was running, i am not surprised it filled up, Its an old 2012 mac laptop with a 6 TB drive attached.
