I set up channels DVR with my IPTV provider. Setup didn't ask for the separate program guide address. The channels are there, but no guide so I can't see what is coming up and can't use the DVR. I did get these features working on UHF server. Any ideas?
Please show the configuration for your Source's Custom Channels. That's where the Guide URL should be entered.
I go to manage sources? I find my source and the channels there, but don't see custom channels...
Can you explain it step by step. My options on settings on channels DVR are very limited... I cannot find Custom Channels, either through the AppleTv or my Android phone.
In a web browser go to http://serverip:8089 then go to settings/sources in there find your m3u source go to manage/edit settings at the bottom enter your xmltv source.
Thanks. I get 'site is not available." I tried two browsers, including Chrome. Hmm...
I suspect you clicked his link directly - it was an example. Try this one:
http://my.channelsdvr.net
did you replace serverip with your servers local ip address?
did you install the backend on the server of your choice? (Channels — Channels DVR Server)
Silly me and my elderly brain. I did copy and paste! I got there by putting in the whole address. However, I had to delete the app and reinstall to get it working. Now we will if the recording part works. I couldn't get series recording working on UHF, so I thought I would try Channels. Thanks again everyone.
