I installed the server on Windows 11, and now every time I reboot, Edge opens on settings page. Can someone help me turn this off? The startup apps page shows ChannelsDVR enabled and Edge is not enabled. Thanks.
What if you disable on the startup apps page?
Perhaps you installed as a windows service so that's not necessary?
Never mind. I turned it off in the startup section of the Task Manager and all is well.
It must just run as a service because it still works after disabling in startup. Thanks.
