sounds like moving to a new computer (actually this same one) is my best bet.
and you can go on to help others (who unlike me, haven't messed it up this bad!)
last question (I hope): How long should it take in the "Setup Storage" step of the restore wizard to restore the backed up db?
A couple seconds
Refresh the main page if it seems stuck
Or check the log tab for errors
Could be the latest backup is corrupt so you could try an older one
When it loads the backup files, it only loads the ones from tonight---how do I force it to load a backup from 2 days ago? The 2-day old backup is in the DVR directory from before---I can see it there, but even though the wizard looks in the DVR directory from before (the same old path), it only loads tonight's backups as possible choices.
create an Old folder inside Database and move all the backup- except the one you want to use inside there
Then it should show just that one to let you restore
Update: In the ProgramData>ChannelsDVR, many things have now populated. I see directories for all my custom m3u channels, and the recorder.db and the settings.db folders seem robust. But The Channels Server will still not load. Perhaps there are additional log files that will help diagnose.
Is the exe running in task manager?
There are 9 apps running. It is not one of them.
channels-dvr.exe is sitting the the "latest" folder
It must be crashing still.
What's the last line in the log file
2022/07/18 23:30:11.421981 [SYS] Starting Channels DVR v2022.06.20.0235 (windows-x86_64 pid:21264) in C:\ProgramData\ChannelsDVR\data
2022/07/18 23:30:12.896967 [SYS] Started HTTP Server
2022/07/18 23:30:13.546458 [HDR] Found 1 devices
2022/07/18 23:30:13.621085 [ERR] Failed to refresh auth: missing oauth client
2022/07/18 23:30:13.752951 [SYS] Bonjour service running for dvr-jon-lenovo-2021.local. [192.168.1.112]
2022/07/18 23:31:49.058788 [ERR] Unexpected m3u response for AiryTV: 404 Not Found
2022/07/18 23:31:49.433880 [ERR] Unexpected m3u response for HeroGoTV: 404 Not Found
2022/07/18 23:31:49.715478 [M3U] Refreshed lineup for IPTVmaybe with 1828 channels
2022/07/18 23:31:50.106704 [ERR] Unexpected m3u response for WatchyourTV: 404 Not Found
2022/07/18 23:31:50.484551 [ERR] Unexpected m3u response for BumblebeeTV: 404 Not Found
2022/07/18 23:31:50.855088 [ERR] Unexpected m3u response for DistroTV: 404 Not Found
2022/07/18 23:31:50.913190 [M3U] Refreshed lineup for PBS2022 with 140 channels
2022/07/18 23:31:51.224658 [M3U] Refreshed lineup for PlutoNoDocker with 338 channels
2022/07/18 23:31:51.363398 [M3U] Refreshed lineup for StirrNoDocker with 111 channels
2022/07/18 23:31:52.151312 [M3U] Refreshed lineup for PLEXLiveTV with 271 channels
2022/07/18 23:31:52.185461 [M3U] Refreshed lineup for SamsungTVPlus with 211 channels
2022/07/18 23:31:52.410858 [M3U] Refreshed lineup for TubiChannels with 138 channels
2022/07/18 23:31:52.764606 [M3U] Refreshed lineup for BigList with 211 channels
2022/07/18 23:31:54.133016 [ERR] Unexpected m3u response for Combinedlist: 404 Not Found
2022/07/18 23:31:54.237788 [M3U] Refreshed lineup for GithubList with 52 channels
2022/07/18 23:31:54.448182 [ERR] Unexpected m3u response for Many: 404 Not Found
2022/07/18 23:31:54.611889 [ERR] Unexpected m3u response for Mnay2: 404 Not Found
2022/07/18 23:31:54.992511 [ERR] Unexpected m3u response for UnknownPlaylist: 404 Not Found
2022/07/18 23:31:54.992511 [DVR] Restored backup backup-20220716.150503 from D:\Channels 11-2021\Database
2022/07/18 23:32:19.888618 cannot open index, metadata missing
2022/07/19 14:14:26.519851 [SYS] Starting Channels DVR v2022.06.20.0235 (windows-x86_64 pid:10720) in C:\ProgramData\ChannelsDVR\data
2022/07/19 14:14:26.959870 [SYS] Started HTTP Server
2022/07/19 14:14:28.138972 [HDR] Found 1 devices
2022/07/19 14:14:29.702637 [ERR] Unexpected m3u response for HeroGoTV: 404 Not Found
2022/07/19 14:14:29.795054 [M3U] Refreshed lineup for SamsungTVPlus with 211 channels
2022/07/19 14:14:30.133037 [M3U] Refreshed lineup for TubiChannels with 138 channels
2022/07/19 14:14:30.544653 [ERR] Unexpected m3u response for UnknownPlaylist: 404 Not Found
2022/07/19 14:14:30.868579 [M3U] Refreshed lineup for IPTVmaybe with 1828 channels
2022/07/19 14:14:31.219513 [ERR] Unexpected m3u response for Mnay2: 404 Not Found
2022/07/19 14:14:31.359849 [M3U] Refreshed lineup for PlutoNoDocker with 338 channels
2022/07/19 14:14:31.470903 [M3U] Refreshed lineup for StirrNoDocker with 111 channels
2022/07/19 14:14:31.518151 [M3U] Refreshed lineup for PBS2022 with 140 channels
2022/07/19 14:14:31.580985 [M3U] Refreshed lineup for PLEXLiveTV with 271 channels
2022/07/19 14:14:32.004773 [ERR] Unexpected m3u response for WatchyourTV: 404 Not Found
2022/07/19 14:14:32.419358 [ERR] Unexpected m3u response for AiryTV: 404 Not Found
2022/07/19 14:14:32.447478 [M3U] Refreshed lineup for BigList with 211 channels
2022/07/19 14:14:32.951893 [ERR] Unexpected m3u response for BumblebeeTV: 404 Not Found
2022/07/19 14:14:34.182553 [ERR] Unexpected m3u response for Combinedlist: 404 Not Found
2022/07/19 14:14:34.289506 [M3U] Refreshed lineup for GithubList with 52 channels
2022/07/19 14:14:34.792523 [ERR] Unexpected m3u response for DistroTV: 404 Not Found
2022/07/19 14:14:34.892528 [ERR] Unexpected m3u response for Many: 404 Not Found
2022/07/19 14:14:44.098687 bolt.Open(): flock error: timeout
2022/07/19 14:14:44.116615 bolt.Close(): funlock error: The segment is already unlocked.
2022/07/19 14:14:44.117615 timeout
2022/07/19 14:15:07.938493 [SYS] Starting Channels DVR v2022.06.20.0235 (windows-x86_64 pid:21500) in C:\ProgramData\ChannelsDVR\data
2022/07/19 14:15:08.318147 [SYS] Started HTTP Server
2022/07/19 14:15:09.409206 [HDR] Found 1 devices
2022/07/19 14:15:10.220821 [ERR] Unexpected m3u response for DistroTV: 404 Not Found
2022/07/19 14:15:10.610562 [ERR] Unexpected m3u response for UnknownPlaylist: 404 Not Found
2022/07/19 14:15:10.987770 [ERR] Unexpected m3u response for WatchyourTV: 404 Not Found
2022/07/19 14:15:11.368075 [ERR] Unexpected m3u response for AiryTV: 404 Not Found
2022/07/19 14:15:11.410325 [ERR] Unexpected m3u response for Mnay2: 404 Not Found
2022/07/19 14:15:11.468334 [M3U] Refreshed lineup for PLEXLiveTV with 271 channels
2022/07/19 14:15:11.715817 [M3U] Refreshed lineup for PlutoNoDocker with 338 channels
2022/07/19 14:15:12.099021 [ERR] Unexpected m3u response for BumblebeeTV: 404 Not Found
2022/07/19 14:15:13.187462 [ERR] Unexpected m3u response for Combinedlist: 404 Not Found
2022/07/19 14:15:13.227711 [M3U] Refreshed lineup for GithubList with 52 channels
2022/07/19 14:15:13.368195 [M3U] Refreshed lineup for IPTVmaybe with 1828 channels
2022/07/19 14:15:13.388604 [ERR] Unexpected m3u response for Many: 404 Not Found
2022/07/19 14:15:13.997092 [M3U] Refreshed lineup for PBS2022 with 140 channels
2022/07/19 14:15:14.027582 [M3U] Refreshed lineup for SamsungTVPlus with 211 channels
2022/07/19 14:15:14.180200 [M3U] Refreshed lineup for TubiChannels with 138 channels
2022/07/19 14:15:14.210678 [M3U] Refreshed lineup for BigList with 211 channels
2022/07/19 14:15:14.615224 [ERR] Unexpected m3u response for HeroGoTV: 404 Not Found
2022/07/19 14:15:14.712378 [M3U] Refreshed lineup for StirrNoDocker with 111 channels
2022/07/19 14:15:17.689347 cannot open index, metadata missing
2022/07/19 14:15:36.442859 [SYS] Starting Channels DVR v2022.06.20.0235 (windows-x86_64 pid:18580) in C:\ProgramData\ChannelsDVR\data
2022/07/19 14:15:36.629227 [SYS] Started HTTP Server
2022/07/19 14:15:37.810981 [HDR] Found 1 devices
2022/07/19 14:15:38.073970 [M3U] Refreshed lineup for BigList with 211 channels
2022/07/19 14:15:38.471685 [ERR] Unexpected m3u response for HeroGoTV: 404 Not Found
2022/07/19 14:15:38.542993 [M3U] Refreshed lineup for StirrNoDocker with 111 channels
2022/07/19 14:15:38.734990 [ERR] Unexpected m3u response for Many: 404 Not Found
2022/07/19 14:15:38.760888 [M3U] Refreshed lineup for PBS2022 with 140 channels
2022/07/19 14:15:38.808772 [M3U] Refreshed lineup for SamsungTVPlus with 211 channels
2022/07/19 14:15:38.970877 [M3U] Refreshed lineup for TubiChannels with 138 channels
2022/07/19 14:15:39.348740 [ERR] Unexpected m3u response for AiryTV: 404 Not Found
2022/07/19 14:15:40.425445 [ERR] Unexpected m3u response for Combinedlist: 404 Not Found
2022/07/19 14:15:40.794904 [ERR] Unexpected m3u response for DistroTV: 404 Not Found
2022/07/19 14:15:40.843959 [M3U] Refreshed lineup for GithubList with 52 channels
2022/07/19 14:15:40.992001 [ERR] Unexpected m3u response for Mnay2: 404 Not Found
2022/07/19 14:15:41.357390 [ERR] Unexpected m3u response for UnknownPlaylist: 404 Not Found
2022/07/19 14:15:41.734177 [ERR] Unexpected m3u response for WatchyourTV: 404 Not Found
2022/07/19 14:15:42.107357 [ERR] Unexpected m3u response for BumblebeeTV: 404 Not Found
2022/07/19 14:15:42.236382 [M3U] Refreshed lineup for IPTVmaybe with 1828 channels
2022/07/19 14:15:43.036609 [M3U] Refreshed lineup for PLEXLiveTV with 271 channels
2022/07/19 14:15:43.134746 [M3U] Refreshed lineup for PlutoNoDocker with 338 channels
2022/07/19 14:15:46.679005 cannot open index, metadata missing
2022/07/19 14:17:07.262191 [SYS] Starting Channels DVR v2022.06.20.0235 (windows-x86_64 pid:18856) in C:\ProgramData\ChannelsDVR\data
2022/07/19 14:17:07.754612 [SYS] Started HTTP Server
2022/07/19 14:17:08.891167 [HDR] Found 1 devices
2022/07/19 14:17:09.437419 [ERR] Unexpected m3u response for Mnay2: 404 Not Found
2022/07/19 14:17:09.588861 [M3U] Refreshed lineup for TubiChannels with 138 channels
2022/07/19 14:17:10.018267 [ERR] Unexpected m3u response for AiryTV: 404 Not Found
2022/07/19 14:17:10.115503 [M3U] Refreshed lineup for BigList with 211 channels
2022/07/19 14:17:11.216524 [ERR] Unexpected m3u response for Combinedlist: 404 Not Found
2022/07/19 14:17:11.590220 [ERR] Unexpected m3u response for DistroTV: 404 Not Found
2022/07/19 14:17:11.972755 [ERR] Unexpected m3u response for HeroGoTV: 404 Not Found
2022/07/19 14:17:11.999650 [M3U] Refreshed lineup for PBS2022 with 140 channels
2022/07/19 14:17:12.032920 [M3U] Refreshed lineup for PLEXLiveTV with 271 channels
2022/07/19 14:17:12.081002 [M3U] Refreshed lineup for GithubList with 52 channels
2022/07/19 14:17:12.188540 [M3U] Refreshed lineup for PlutoNoDocker with 338 channels
2022/07/19 14:17:12.225982 [M3U] Refreshed lineup for SamsungTVPlus with 211 channels
2022/07/19 14:17:12.276837 [M3U] Refreshed lineup for StirrNoDocker with 111 channels
2022/07/19 14:17:12.660801 [ERR] Unexpected m3u response for UnknownPlaylist: 404 Not Found
2022/07/19 14:17:13.041174 [ERR] Unexpected m3u response for WatchyourTV: 404 Not Found
2022/07/19 14:17:13.438711 [ERR] Unexpected m3u response for BumblebeeTV: 404 Not Found
2022/07/19 14:17:13.564605 [M3U] Refreshed lineup for IPTVmaybe with 1828 channels
2022/07/19 14:17:13.703844 [ERR] Unexpected m3u response for Many: 404 Not Found
2022/07/19 14:17:25.089020 bolt.Open(): flock error: timeout
2022/07/19 14:17:25.089020 bolt.Close(): funlock error: The segment is already unlocked.
2022/07/19 14:17:25.089020 timeout
Do any of these work?
http://192.168.1.112:8089/admin/settings
http://192.168.1.112:8089/debug/stack
http://192.168.1.112:8089/debug/stack this one gives me a pile of data which I'm sure you'd like to see.
http://192.168.1.112:8089/admin/settings this one just starts that "booting" process again.
also, in task manager, now channels-dvr.exe is in background processes, but it kind of flashes on and off periodically. ?
also got this just now:
A Javascript error has occurred!
Please refresh the browser after reporting this issue on Channels Community or to [email protected].
this.state.jobs.forEach is not a function
function@http://127.0.0.1:8089/admin/components/JobList.js:28
Vj@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:187
Nn1@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:186
ri1@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:269
$n1@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:250
J82@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:250
Mm@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:250
Kj@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:243
oi1</J91/<@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:123
A71</h6.unstable_runWithPriority@http://127.0.0.1:8089/node_modules/scheduler/cjs/scheduler.production.min.js:18
co@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:122
J91@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:123
Lr@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:122
gn@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:237
enqueueSetState@http://127.0.0.1:8089/node_modules/react-dom/cjs/react-dom.production.min.js:133
u71</_l.prototype.setState@http://127.0.0.1:8089/node_modules/react/cjs/react.production.min.js:12
navigator.serviceWorker.register('/service-worker.js').then(function@http://127.0.0.1:8089/admin/components/JobList.js:21
rW1</E4.serverRequest@http://127.0.0.1:8089/admin/globals.js:77
stack file sent
Please try a fresh install again, but before doing a restore update to prerelease. Click the down arrow next to Check for Update and select Pre-release
and a fresh install is essentially an overwrite of what's there? or do I delete the Channels DVR folder from the Program data folder, first?
