The server loaded fine this morning. Tried to load a client and it froze up. Ever time I try to load channels it hangs up on “starting up”
Sounds like a network issue. Do you know how to troubleshoot one?
Thanks for the reply. I ended up just re-installing the software and it is fine now.
The problem came up when I tried to set up a source to add pluto tv. Not sure if I entered the sources incorrectly but the program locked up and would not respond.
I am all good now though.
