Please I need the beta too thanks
Hi
Please send a beta update
Thx
Please can I have the beta - no TV
Mine just went grey. ‘Done’ did nothing.
A Beta app invite would be greatly appreciated as I lost channels on all of my Apple TVs they were all set to auto update.
Many thanks
Back up and running - much obliged!
Beta is running fine here. Thanks for the quick solution.
Please send beta link
Beta link please
I got the same message when I turned on ATV. then again later and I was in a different app so it must have been trying to update in the background. I used Channels a little later and it was slow to load but otherwise seemed to work ok.
I cannot acces. I use channels all the time. I love it. However I can not use it and it’s the weekend. Please help.
I’m in the same boat! Could I have the beta please?
Please send beta code
Heya, I need a beta code as well. I purchased the AppleTV app with the e-mail address I am using in this forum.
Hi team same issue with App Store version . I should have checked this page before deleting and trying to reinstall
Can you please share the beta app ? Thanks
Can I have a beta invite? Thanks.
Can I have the beta as well please? I figured I would wait it out, but getting the TV shakes.
Please send beta. Thanks
same problem here
Sent!
Please send beta.
