What client are you trying to watch it on, the servers player? If so, I noticed the tuning on the Channels admin Live TV player takes longer to tune in and could be timing out. It also looks as if the stream is requesting an HLS stream which will not play the MPEG-TS stream. If you add it again, make sure you create a new Source with a different name with MPEG-TS selected and Try on a different client other than the Admin player. I would expect the Channels log to look more like this 2026/11/11 12:08:53.028126 [TNR] Opened connection to M3U-Charon for ch24707 CHARGE! than this: 2026/11/11 04:42:15.607407 [HLS] Couldn't generate master playlist for ch7539-dANY-ip192.168.2.174: stream stopped. Also, make sure your server can access Charon at 192.168.2.160:48590 I'm sorry to not be more help. I do not have access to Xfinity to verify if your links are correct or not.
I'm a big fan of keeping things simple. I tend to overcomplicate things when I should have left well enough alone.
I set it up again with a new name and retried playing a channel directly from the server machine (I'd been using my local client PC last night). No appreciable difference (log below).
2026/11/12 00:07:38.093015 [ERR] Failed to start stream for ch7511: M3U: 901 Tuner Unreachable: Timeout after 20s connecting to: http://192.168.2.160:48590/stream/xfinity/comet-xf
2026/11/12 00:07:38.093015 [HLS] Couldn't generate stream playlist for ch7511-dANY-ip192.168.2.160: M3U: 901 Tuner Unreachable: Timeout after 20s connecting to: http://192.168.2.160:48590/stream/xfinity/comet-xf
2026/11/12 00:07:38.093015 [HLS] Stopping transcoder session ch7511-dANY-ip192.168.2.160 (out=0s finished=false first_seq=0 last_seq=-1)
I know it says [HLS] but it's definitely set for mpeg-ts:
I can reach the dashboard easily from both client & server machines. I also tested playback on the Channels app in my Android phone, as well as with VLC, so it can't be a firewall thing (as had occurred to me last night). I also tried with Nucleus. None are able to show the stream. To test whether recording would behave differently from watching, I set up two recordings from the Guide. Both showed as "failing."
Could it possibly be:
- I have Prismcast running, which also uses Chrome
- I have an older version of Chrome (frozen at .148 for Prismcast, although that might no longer be necessary).
- Inadequacy of my hdmi dummy plug (it supposedly delivers (according to the listing when I bought it): "Default Resolution 1920x1080@60Hz Highest 3840x2160@60Hz " and has no drivers or software to configure. It's a passthrough plug, and the other end goes to my 3-way HDMI switch, which is usually switched to my client PC. It works ok for Prismcast, though.
The streams provide by this project are in mpeg-ts
Make sure the web interface is accessible on the khome network.
Try putting the playlist through VLC player.
The streams should play without a problem.
thanks
Yes, the web interface is accessible on my home network.
Yes, it's set to mpeg-ts
VLC will read the playlist but won't play anything.
None of the other clients I've tried (Android phone app, Nucleus) play anything.
@Bobby_Vaughn PR submitted to add Xfinity premium movie channels (HBO, Showtime and MGM+) to the "verified table" for Gracenote IDs, as they don't match otherwise:
Thank you, I will work on that today.
I am looking into this to see if I can find out why it is not working for you. It's hard to track something down that I can't reproduce it. I'm going to set it up on another PC and try and reproduce it this evening. What type of setup do you have for Channels Server? Is it a docker install or native Windows, Mac or Linux install?
I will test an older version of Chrome. I have been testing and running it on Versions 156 to 157. Can you watch Xfinity from the Chrome browser on that PC?
I found a sling log in page if the client being used can get a code generated.
Edit: Channels (not Docker) is installed natively on Windows 11, Channels ver 2026.11.02.1456. I just verified that I can watch Xfinity from Chrome on the server PC. I'm using the 1.0.0 version of Charon. When I set the window mode to "visibleDebug" the Chrome screen displays the Xfinity splash stream, then the guide screen. Last night after that it would display a couple seconds of the actual program, then cycle through that sequence again. Just now, it cycles before displaying the few seconds of program, so just spash screen, guide screen. The Channels logs continue to say "server unreachable."
Thanks for looking into this. I'll be offline for 1-2 hours, but glad to checkj/try stuff after that.
I think it is timing out in channels. When you have time, make sure your Channels client has Streaming Quality set to Original. Make sure the channel you select is a good, working channel. Paste the Charon log from the tune attempts. No rush on it. I will be busy for the rest of the evening.
V 1.0.2 released.
Is this the correct one? It wasn't on my list of settings, so I added it, and it showed as "original," which implies that was the default anyway:
After adding that to the list I checked again and no change. I verified that the channels I'm trying are good channels - that is, they play fine in Chrome by itself.
Most recent logs:
[21:26:15] [Tuner 1] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> France 24...
[21:26:35] [Tuner 1] Stream closed by client (France 24).
[21:26:35] [Tuner 2] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> France 24...
[21:26:55] [Tuner 2] Stream closed by client (France 24).
[21:26:55] [Tuner 1] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> France 24...
[21:27:15] [Tuner 1] Stream closed by client (France 24).
[21:27:15] [Tuner 2] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> France 24...
[21:27:35] [Tuner 2] Stream closed by client (France 24).
[21:28:58] [Tuner 1] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> Columbia Broadcasting System...
[21:29:18] [Tuner 1] Stream closed by client (Columbia Broadcasting System).
[21:29:18] [Tuner 2] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> Columbia Broadcasting System...
[21:29:38] [Tuner 2] Stream closed by client (Columbia Broadcasting System).
[21:29:38] [Tuner 1] Launching Chrome (Ext v33.1110.2133.34) for Xfinity Stream -> Columbia Broadcasting System...
[21:29:58] [Tuner 1] Stream closed by client (Columbia Broadcasting System).
I'll be around on & off until about 7am Eastern.
I'm not convinced the problem is with my Channels settings, though, as I'm under the impression the M3U is supposed to work in VLC. In my case, it doesn't. It can open the URL and see the playlist, but it can't play anything.
I tested the new sling provider ad-on
appears video looks good but it is playing multiple copies of the audio.
Tried YTTV and it was fine.
Tested the channel in VLC and in Channels.
Streams plays good just plays a second copy of the audio.
Sounds like an echo.
I tred with get tv and Filmrise classics.
thanks
@Bobby_Vaughn I was able to duplicate this issue with Sling channels on a Android client -- so I'll work on a fix today.
@Bobby_Vaughn I'm still unable to duplicate this issue. Hopefully someone else with Xfinity will give this a try soon, as all of the channels I've tried across multiple clients, play fine via Charon.
@Bobby_Vaughn PR submitted that should fix an issue with duplicate audio in some Sling tunes:
Cool. I'm working on a few changes too. I should have the next release later today.
