Charon Tuner Project
Here's an update on the next release. I have been working on CNN TVE and CBS TVE session health check and management improvements. If tests go well, I will have it ready by Saturday.
I haven't seen that issue with prismcast. But the big difference I think is that I have ESPN Unlimited through my TV provider and so with a Disney+ account linked to that it always works.
I don't have ESPN Unlimited but use my YTTV credentials on Prismast, haven't noticed a need to renew my credentials over the span of several weeks, month+.
Other issues have surfaced of late, but credentials isn't one of them.
I have no idea how Prismcast handles the logins and sessions, I can only go by what I am seeing when I use the browser based login on ESPN site which kills the sessions and requires YTTV credentials to be logged in after a very short time. Once I get everything else figured out, I may revisit it.
Please do revisit.
Thanks
Ok, I am giving ESPN a second chance. It looks like ESPN uses two different tokens, one that expires after 4 hours and one that expires after 6 hours. I'm going to try syncing every 3 hours and see if we can keep them alive and refreshed. I'll know more tomorrow and Saturday.
v1.1.4 released
  • Re-added ESPN TVE
  • Health Check Improvements for CNN, CBS, ESPN and ABC
Some improvements, but still issues to resolve. CNN and ABC TVE are much better, CBS and ESPN TVE are still dropping authentication.
Are there more tve networks planned to be added like Disney Channel, tbs and tnt?
Not at the moment. Once I get the bugs worked out of the current TVE channels, I will look into adding others. TBS and TNT are still supported in Channels DVR TVE stations.
if you have a valid sub to YTTV access is already available. No need to continuiously re-invent the wheel.
i'm counting on the new owners of the Warner channels to start adding DRM in the next year.
They stopped streaming the main channels and there is no reason to keep paying CDNs for the data. it isn't a matter of iff but when.
Enjoy the access methods while they work.
Could this be used on something other then channel dvr like jellyfinn or Emby?
You would need a way to utilize Gracenote ID's for the guide data or supply your own epg. I do not know how other projects deal with m3u playlists, but it should be possible.
You should be able to use the solution quite easily.
Jellyfin and especially Emby have great options for setting up guide data.
I can tell you it works great in Emby. You can use the Charon ip address, http://xxx.xxx.xxx.xxx:48590, as the tuner url and the CDVR address, http://xxx.xxx.xxx.xxx:8089/devices/M3U-Charon/guide/xmltv?duration=1209600, for the epg.
Emby has access to it's own Guide info so long as you have Emby Premiere.
Jellyfin can be configured to work with Schedules Direct (subscription bsaed) through it's API, though there's some feedback that it doesn't work as intended and sometimes your account gets frozen for too many requests. That may be resolved, I've not used Schedules Direct with Jellyfin in some time.
Both can also use EPG Guru which is free.
Channels has the best integration (nearly 100% automated) whereas others requires usually some configuration.
And as @daldana7296 mentioned, you can export Channels guide info if you want to keep Channels in your environment.
