Chasing down Lost connection error
I've been chasing this error for a long time. Mainly it happens during the morning news shows-I would get the error almost every minute or so and have to re-select play. i think maybe I solved the why but not how. If I stopped the recording (I have passes for several morning shows) the error would go away, so it seems that there's something going wrong with recording/playback while recording. i changed the path to another hard drive I have to see if that changes anything but wont know until tomorrow. Anyone have issues like this?
Another thing that seems related is if I watch a recorded show (but not watch while it's being recorded) I sometimes get choppy playback and it will often playback a part that I just watched.
Just make sure you have turned WiFi OFF on your host and have a dedicated DHCP address, otherwise it may be switching back and forth from the Wifi address to the Ethernet address
DHCP reservation (sometimes called a static DHCP lease). It tells your home router to always give the same local IP address to the specific device running your Channels DVR server
The Risk of Leaving Both Active:
they have different hardware addresses, your router treats them as two completely separate devices and assigns them two different local IP addresses
If your server has both Wi-Fi and Ethernet active at the same time, it can cause several issues with Channels DVR:
  • Random Disconnections: Your operating system may dynamically switch traffic between Wi-Fi and Ethernet based on what it thinks is a stronger connection.
ahh-thanks. I'll try it out tomorrow
I had a similar problem. It turned out to be a bad network switch.
I found it using Ping Plotter.
so the problem continues-not just having wifi and ethernet on at same time. Also continues to happen after turning of the recording. Here's a sample from this morning's log:
2026/08/27 07:00:00.005817 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:00:00.005875 [DVR] Waiting 12h30m0s until next job 1787884200-24 House Hunters International
2026/08/27 07:00:00.794749 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:00.795990 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h59m59.994061s
2026/08/27 07:00:04.252090 [IDX] Generating video index for job 1787839200-39
2026/08/27 07:00:05.718450 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:05.718562 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=9%,0%-100% drop=3%
2026/08/27 07:00:30.385798 [TNR] Opened connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:33.959887 [TNR] Closed connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:34.204178 [SNR] Buffer statistics for "TV/Today/Today S74E283 2026-08-27-0700.mpg": buf=0%-11% drop=0%
2026/08/27 07:00:34.252641 [DVR] Job 1787839200-39 Today ended prematurely: 1h59m25.747361s
2026/08/27 07:00:34.485549 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:00:34.515583 [DVR] Waiting 12h29m25s until next job 1787884200-24 House Hunters International
2026/08/27 07:00:37.019870 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:37.020146 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h59m25.484438s
2026/08/27 07:00:39.953934 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:00:39.954078 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=48%,0%-100% drop=25%
2026/08/27 07:01:13.342524 [TNR] Opened connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:01:16.717357 [TNR] Closed connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:01:16.800352 [SNR] Buffer statistics for "TV/Today/Today S74E283 2026-08-27-0700.mpg": buf=0% drop=0%
2026/08/27 07:01:16.832460 [DVR] Job 1787839200-39 Today ended prematurely: 1h58m43.167542s
2026/08/27 07:01:16.937790 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:01:16.937852 [DVR] Waiting 12h28m43s until next job 1787884200-24 House Hunters International
2026/08/27 07:01:17.529346 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:01:17.529558 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h58m43.06212s
2026/08/27 07:01:25.905694 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:01:25.905818 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=18%,0%-64% drop=0%
2026/08/27 07:01:54.991729 [TNR] Opened connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:00.197194 [TNR] Closed connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:00.269548 [SNR] Buffer statistics for "TV/Today/Today S74E283 2026-08-27-0700.mpg": buf=0% drop=0%
2026/08/27 07:02:00.292684 [DVR] Job 1787839200-39 Today ended prematurely: 1h57m59.707317s
2026/08/27 07:02:00.358322 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:02:00.358379 [DVR] Waiting 12h28m0s until next job 1787884200-24 House Hunters International
2026/08/27 07:02:00.999307 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:00.999522 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h57m59.641555s
2026/08/27 07:02:07.032781 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:07.032911 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=9%,0%-58% drop=0%
2026/08/27 07:02:38.308199 [TNR] Opened connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:42.519974 [TNR] Closed connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:42.638729 [SNR] Buffer statistics for "TV/Today/Today S74E283 2026-08-27-0700.mpg": buf=0% drop=0%
2026/08/27 07:02:42.639689 [DVR] Job 1787839200-39 Today ended prematurely: 1h57m17.360312s
2026/08/27 07:02:43.184833 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:02:43.184878 [DVR] Waiting 12h27m17s until next job 1787884200-24 House Hunters International
2026/08/27 07:02:43.772615 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:43.772913 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h57m16.815061s
2026/08/27 07:02:46.309317 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:02:46.312575 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=66%,0%-100% drop=33%
2026/08/27 07:03:20.577973 [TNR] Opened connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:03:25.238699 [TNR] Closed connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:03:25.286717 [SNR] Buffer statistics for "TV/Today/Today S74E283 2026-08-27-0700.mpg": buf=0% drop=0%
2026/08/27 07:03:25.288022 [DVR] Job 1787839200-39 Today ended prematurely: 1h56m34.711979s
2026/08/27 07:03:25.333302 [DVR] Starting job 1787839200-39 Today on ch=[9261]
2026/08/27 07:03:25.333363 [DVR] Waiting 12h26m35s until next job 1787884200-24 House Hunters International
2026/08/27 07:03:25.939852 [TNR] Opened connection to M3U-George3 for ch9261 NBC 8 (KGW) PORTLAND
2026/08/27 07:03:25.940103 [DVR] Recording for job 1787839200-39 from M3U-George3 ch9261 into "TV/Today/Today S74E283 2026-08-27-0700.mpg" for 1h56m34.666584s
2026/08/27 07:03:30.984478 [TNR] Closed connection to M3U-George2 for ch9131 NBC 8 (KGW) PORTLAND
2026/08/27 07:03:30.984899 [SNR] Buffer statistics for 192.168.4.52 (Living Room (3)) for ch9131 NBC 8 (KGW) PORTLAND: buf=10%,0%-51% drop=0%
