Chrome dbus issue with Chromium 119 on TrueNAS Core (FreeBSD)
Same, Logs have been submitted as 8d7c97e6-b43b-4ff8-afd1-e35b6909c4ca
Are you able to run chromium yourself?
Are you able to downgrade chromium? 119.0.6045.105 came out October 31st and only came out for freebsd last week, so it's likely that you just installed it and that was the source of the issues.
It looks like chromium 119 is requiring dbus (which it appears you aren't running)... and I'm not sure how to fix it.
Not sure if I can downgrade chromium but I'll check it out.
Is it possible to downgrade the server if I can't do chromium.
I don't think downgrading the server will make a difference. There isn't anything we changed that would impact the way you're running chromium.
Are you able to run chromium on the command line?
It's TrueNAS Core and the Jail for the server uses freeBSD as a base.
So it's a shell interface and I don't have a clue what the command would be to use chromium from there.
Ah, sorry. I don't really know about how TrueNAS works and how it interacts with dbus.
