Chrome HDMI for Channels (CH4C): Chrome channel tuner plus HDMI encoder
I wonder if it was this? not sure if initial setup did this correctly and I changed it? anyway I've turned it off for now.
nice changes. so far so good. I just heard the first recording start up.
I just have basic DtvStream Entertainment, so i can't test the overflow.
yes, now i'm not worried about a pc reboot. (still need to test though) this is my biggest issue with docker. I have to manually make sure portainer properly started, restart ah4c, refresh cdvr sources everytime.
edit: @anon38303228
  • Restarts CH4C automatically if it crashes or exits.
must run ch4c service stop under administrator for the service to stay stopped.
without admin the service will restart automatically.
so even with docker shut down I'm unable to get 2 encoders working with the built in dual hdmi on the nano a1. I think the 2nd chrome instance just takes too long to actually load the stream and something times out.
I may try a usb hdmi later, but I'm going to try and leave my setup alone for a bit.
i've been using ch4c to record news since quality doesn't matter (although it's not bad most of the time)
the browser window does remember if CC was on, and does remember the CC settings, but for me it always displays large font, until I navigate to CC settings, then just by loading that popup, the CC reverts to the saved preference.
not sure if there's anything that can be done with that as this is the first chrome grab project i've used.
@anon38303228
running your latest commit. :+1:
@dravenst
might be time for some type of versioning. update when idle like cdvr would be great!
I've been using admin console to service stop, uninstall, replace ch4c exe, reinstall. then I use a user ps1 to stop the service and let it self restart.
I would have thought you'd be passing the video card through, so that your Windows VM would be using the Windows drivers for that card, rather than VirtIO drivers.
bhwaaahhh! I finally had that problem I've read so much about...
Keep Watching
monitoring
the 3pm recording was me restarting ch4c service. just closing the window did not restart the stream in the new window.
i know on dtv devices the 'exit' key will always back out to the full screen channel.
I'd actually be fine with sending the channel# for the start of any recording even if that channel has already been tuned.
not sure what i'm doing differently, but my boxes on tv's (no adb) never sleep. even free guest youtube rarely asks on my cat's tv.
I do have the default 4h in ah4c whatever it's sending, but i've never had to worry about it.
DTV just rolled out a setting on the app that changes the time from 4 to12 hours. I checked on the Firestick App and it’s there under Settings, Preferences, Who's watching, select your option (4 or12).
This is only for apps and should not affect our Osprey's. That setting may be there on the web interface but haven’t looked for it.
I did post a new release (0.5.3) with the latest updates and PR's. Thanks @anon38303228 for the contribution on running as a native windows service. I made a minor modification to it to be compatible with running via an RDP session too.
glad it was minor to you. kinda big for me since I had been relying on chromeRD. just yesterday i had an extended outage and chrome doesn't work without internet. lucky I always have a liberkey handy.
Nothing would be designed in like that on purpose. If you suspect there's something going on in that regard, I'd suggest forking it and having a look. The DTV portion of CH4C was largely based on what was done in Prismcast.
No worries -- we're good. Off the top of my head, I can't think of anything in ch4c or Prismcast that would fall into the category you're describing by design. So if there is an issue like that, I feel reasonably confident it would be a bug.
That would be great. If there is a bug, it could very well be present in Prismcast's DTV code too.
I'm not aware of anything either that would cause this behavior. I added some logic in the latest .5 version to automate re-login (where a logout is detected) for certain services when a stream fails to start, but DirecTV is not part of that scope.
