Client Settings Live TV settings are now grayed out
I was experimenting with the Live TV settings under Client Settings. However, I found that I should be using Global Client Settings instead. When I went to reset them, I found that the below items were grayed out and I could neither unset or set them. How do I reset the following settings to default?
Guide Collections
Favorites Collection
Show All Channels Collection
Show HD Channels Collection
Remove them from global settings
They remain grayed out whether the global client settings are toggled on or off.
I haven't tried trashing all global client settings because I don't know what the result would be.
Thank you.
That's expected if set to on or off on the server.
It should be removed from the server side settings.
