At Home.
Clients losing connection to Server.
I have been having this problem lately.
On Firestick 4K, Onn 4k Android TV box, iPhone.
I am on the current stable release 2023.01.23.1746.
The Guide comes up empty or it says server not found or some such.
I say connect to server, then Try Again, nothing works.
It goes to the At Home selection, I select that and enter the Server IP addrs.
It says Server not found at that address.
I try to use my iPhone to go to the Web UI to uncheck, Re-check Bonjour, but iPnone also cannot get to Server.
Other Clients are getting to the Server.
I finally go to my Win 11 laptop, go to the web UI, uncheck Bonjour, recheck Bonjour.
Now all is OK.
What is going on???
Not good, wife getting pissed.
Thanks for any suggestions.
LOG
2023/03/27 21:22:18 [Recovery] 2023/03/27 - 21:22:18 panic recovered:
write tcp 192.168.0.217:8089->192.168.0.197:56752: wsasend: An established connection was aborted by the software in your host machine.
github.com/gin-gonic/[email protected]/render/json.go:58 (0x636e5e)
github.com/gin-gonic/[email protected]/context.go:899 (0x63c8b7)
github.com/gin-gonic/[email protected]/context.go:942 (0x121edc5)
github.com/fancybits/channels-server/http_device.go:369 (0x121ed79)
github.com/gin-gonic/[email protected]/context.go:169 (0x121ed0d)
github.com/fancybits/channels-server/http_device.go:360 (0x121ec47)
github.com/gin-gonic/[email protected]/context.go:169 (0x121be81)
github.com/fancybits/channels-server/http_device.go:87 (0x121bdac)
github.com/gin-gonic/[email protected]/context.go:169 (0x1213c03)
github.com/fancybits/channels-server/http.go:273 (0x12138f7)
github.com/gin-gonic/[email protected]/context.go:169 (0x121386a)
github.com/fancybits/channels-server/http.go:250 (0x121384f)
github.com/gin-gonic/[email protected]/context.go:169 (0x1213727)
github.com/fancybits/channels-server/http.go:242 (0x121309a)
github.com/gin-gonic/[email protected]/context.go:169 (0x6457c1)
github.com/gin-gonic/[email protected]/recovery.go:107 (0x6457ac)
github.com/gin-gonic/[email protected]/context.go:169 (0x644906)
github.com/gin-gonic/[email protected]/logger.go:240 (0x6448e9)
github.com/gin-gonic/[email protected]/context.go:169 (0xd630b9)
github.com/gin-contrib/[email protected]/sessions.go:65 (0xd630a5)
github.com/gin-gonic/[email protected]/context.go:169 (0xd5d2c1)
github.com/gin-contrib/[email protected]/gzip.go:47 (0xd5d299)
github.com/gin-gonic/[email protected]/context.go:169 (0x12144a5)
github.com/fancybits/channels-server/http.go:363 (0x1214491)
github.com/gin-gonic/[email protected]/context.go:169 (0x643a10)
github.com/gin-gonic/[email protected]/gin.go:598 (0x643678)
github.com/gin-gonic/[email protected]/gin.go:554 (0x6431b1)
net/http/server.go:2947 (0x33968b)
net/http/server.go:1991 (0x334966)
runtime/asm_amd64.s:1594 (0x7ef20)
2023/03/27 21:22:35.411193 [TVE] stream timestamps: cnni: start_at=2023-03-27T21:12:27-05:00 end_at=2023-03-27T21:22:20-05:00 live_delay=8.5581934s
2023/03/27 21:22:35.411193 [TNR] Opened connection to TVE-Cox for ch6032 CNNI
2023/03/27 21:22:35.449489 [HLS] Starting live stream for channel 6032 from 127.0.0.1 (bitrate=4549)
2023/03/27 21:22:36.823905 [HLS] Probed live stream in 1.3692305s: h264 1280x720 progressive 1891370bps
2023/03/27 21:22:43.105196 [HLS] Stopping transcoder session ch6032-dANY-ip127.0.0.1 (out: 0s, finished: false)
2023/03/27 21:22:43.114165 [TNR] Closed connection to TVE-Cox for ch6032 CNNI
2023/03/27 21:22:43.130349 [SNR] Buffer statistics for ch6032 CNNI: buf=0% drop=0%
