I have Apple TV 4K, using HD Homerun Prime. When I view certain channels in the Apple TV channels app the closed captions don’t show the correct words. It is just a bunch of garbled together letters or symbols. It happens on HBO and Showtime mainly. The weird thing is if I go into Plex and watch the same channel live the closed captions are there perfect. I would much rather use the awesome channelsdvr and app but if the closed captions can’t get working this is a no go. It has been like this ever since I tried it out a for a few months, I was hoping for a fix but nothing so far. Thanks for any help.
We can only fix issues that people report to us
Please capture a raw tuner sample from one of those channels and email to [email protected]
Say your tuner is 10.0.0.5 and an example channel is 745, visit this URL in Chrome to download a 30s sample:
http://10.0.0.5:5004/auto/v745?duration=30
Thanks for the sample video. I was able to find the bug and fix it for the next version of the app.
Thank you again sir!!!
Channels 3.1.9 is available on the App Store today with a fix for this issue.
Is this working for you now?
Man you are awesome, it works perfectly. I tested HBO, Showtime, etc. all channels have perfect closed captions now. Not sure what it was but the update worked perfect. Thank you for taking the time to interact and help me, you have earned my business and I will spread the word about the channels app. Thanks again!!!
