Combining HDHR-CC and OTA HDHR 'Guide'
I use 2 HDHR-CC currently but I'd like to add an OTA HDHR device. Does Channels DVR combine the channels all into the same guide or what? What would the 'Guide' look like all of the OTA first and then the Cable Channels? Very local OTA for me would be very few channels with no major networks. Could someone that might use Comcast/Xfinity and also OTA - HDHR maybe post an image of what the 'Guide' might look like? It would be appreciated. Thank you!
Channels are separated as they are numbered differently in the guide data. For example in my case ABC OTA is 2.1 ABC Cable is 702. I favor my OTA Channels.
Thank You!
So Channels DVR will combine them and present them in just same guide? That image is exactly what I was asking for but was hoping for maybe a larger number of channels in the Guide maybe.
It will show all the OTA Enabled Channels and all the enabled Cable TV Channels separately in the same guide . All sources will show up in the Channels DVR Guide.
