Commercial Detection Advanced Settings
v2022.12.06.2055
What do these advanced settings under Commercial Detection do:
Automatically generate commercial editor thumbnails
Start live detection when watching in-progress recording
By default, the thumbnails used are generated on-demand. If you regularly modify/verify the detections, this setting will generate the thumbnails right after the detection occurs, allowing the editor to load more quickly.
By default, detection happens only after a recording is completed. With this setting, if you begin to watch a recording that is still in-progress, commercial detection will immediately occur. The added benefit of having commercials detected while the recording is still happening does involve a trade-off: it can be processor-intensive, and the detections can be less accurate.
