Please recreate and submit diagnostics from the app immediately after.
If you have that recording which reproduces the issue, please send it to us: Dropbox - Submit files
Can you point me at the commercial detection file?
hm?
The issue is not really related to commercial detection.
I need you to click in the app: Settings > Support > Submit Diagnostics, right after it freezes up in the player.
Ok, done (submitted), and here's the vid of me doing so:
Thanks. I would like that maddow recording so I can reproduce locally and fix it.
Can you also confirm if you change Settings > Playback > Advanced > Audio Driver: Default that it works correctly.
Am uploading now... (will take a bit)
File is now uploaded, and you are correct! Moving back to the default audio driver fixes the issue
I was able to reproduce with that file and come up with a fix.
I'm uploading a new TestFlight beta now (v2022.02.09.0150), so please update to that (in about 30 minutes) and try that (with exp audio re-enabled).
Thank you... but I'm not running Testflight builds. Will wait for full release if that's ok?
