Device: 2015 Shield TV with IR built in
Remote: Harmony 650 IR remote
DVR Version: 2018.04.05.2059
Android TV Channels App: 1.0.18
I can see the detected commercial segments while watching a show but am unable to skip commercials while using the Harmony Remote. If I double press the right arrow it fast forwards twice for 30 seconds each. Same with the left arrow, 7 seconds each. If I use my Shield GamePad Controller and double press the right direction pad it will skip commercials. I am just having this odd behavior with the Harmony Remote. I also created a key map on the remote to press right twice and tied it to a physical button and it experienced the same outcome as before with the remote.
Any help is appreciated. Great product!
