Complementing OTA program guide?
A few of the OTA channels have no program information from the default EPG.
But sites like titantv.com provide complete details.
Why is the default EPG missing program information for some channels?
Is there any way to complement the EPG with information from a third-party provider such as titantv.com?
Bring up the Channels server SOURCES page in your browser. Look down on the page under "Live Tv". Find your HDHR tuner. Click on the DOWN arrow next to the GEAR Manage icon , then click on MANAGE LINEUP. Go down the list of your scanned in channels, and find the ones that don't have matched EPG. Then, click on the PENCIL icon on the right side of each of those channels. Scroll down the list of channels that appear, and MATE them to the call letters of their station ID's, if you don't see them already matched. Then just back out, and give it a little time to run a guide update.
For some channels, there is no maching station ID in the drop-down box.
What dows that mean?
That means there's no guide data available for that station in that zip code. IF there's a another station in the list that matches the network, Cbs, ABC, etc, try picking one of those.
If that doesn't work, try switching to another LOCAL zip code nearby, that has those stations. I myself have to use a zipcode from a city that's 15 miles away. IF I use my exact local zip code, it doesn't pick up all my stations.
Top LEFT corner on the Manage screen, shows the zip code it's using. Click the +, and try another one. Wait until the new guide populates. IF you are lucky, you'll find one that works to get the new channels, without losing any of your other channels.
Also select search all lineups and see if you can find the station that way as well.
