Connect on ATV
I asked this on the iOS forum as well (I have an iPad and ATV). Can someone comment on how well the Connect works with ATV? Is the Connect OK or do you need the Extend?
The connect works great, as long as you are using 802.11ac wifi or are wired in to the router. 802.11n works too if they ATV is close to the wifi router.
For reference, the vast majority of Channels users have a CONNECT, and that’s what we recommend on our FAQ (https://getchannels.com/faq)
See the post I just made under the “Extend vs. Connect on iOS” topic for details on my experience.
Excellent. I should be fine - both the TV’s have some CAT6 I pulled from my 1GB router.
