Connecting to DVR server via laptop using lan
Is it possible to connect to my DVR server using my new LAN??
I used to hook in via WiFi but now my Server “Win 11” is connected directly to T-Mobile using Ethernet
I tried hooking a Ethernet cable to my switch and an adapter but I can’t seem to get thru??
Thank You Kevin
PS My old IP is
192.196.12.249
It should work right - Ethernet adapter -> tablet -> switch -> Server
I checked the IP and the first 3 sets of #’s are consistent
Thanx
So your server used to connect via WiFi? Now you connected your server via ethernet?
If that's correct, then your server's IP will have changed. You will need to fine it form your network connection status in Win 11
Network Switch -> T-Mobile LAN connection
Network Switch -> Channels Server
Network Switch -> Laptop
Set Reserved T-Mobile LAN side DHCP IP addresses for Channels Server and Laptop
OR
Network Switch -> Router -> T-Mobile LAN connection
Set Reserved Router DHCP IP addresses for Channels Server and Laptop
I used 1,000 mb’s Ethernet cable for an internal LAN - works great Thanx
Using 5 port NetGear switch
3 ft cable - Network switch -> T-Mobile WiFi - is it a router, modem how to find out - do I need to know
3 ft cable - Network switch ->HdHomeRun
5 ft cable -Network switch -> TV - using adapter for Ethernet -> USB 3.0 - avg: 350mb’s
75 ft cable - Network switch -> Win PC host Channels DVR Server
25 ft cable - Network switch -> iPad Tablet - Apple using USB C - Ethernet Adapter
Do I need a router??
They look pretty cheap!
Do I need to find something specific??
New territory here!
Where would I find the ip for the Ethernet for Win 11 Pro
I hate dumping “IPCONFIG” on you, but, not sure how to ask the question?
If my ip has changed and this info shows my IP as preferred then what would I be looking for??
Thank You Kevin
IPConfig
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 68-1D-EF-41-2D-CC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2607:fb91:3e8b:d096:4b5:75e:808a:ae16(Preferred)
IPv6 Address. . . . . . . . . . . : fdb3:7af:639e:0:148f:31cc:2744:d3b7(Preferred)
Temporary IPv6 Address. . . . . . : 2607:fb91:3e8b:d096:c009:47a6:66b7:196b(Preferred)
Temporary IPv6 Address. . . . . . : fdb3:7af:639e:0:c009:47a6:66b7:196b(Preferred)
Link-local IPv6 Address . . . . . : fe80::6722:d6f4:e7:39cb%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.12.246(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, August 13, 2025 9:47:12 PM
Lease Expires . . . . . . . . . . : Thursday, August 14, 2025 9:47:11 PM
Default Gateway . . . . . . . . . : fe80::dacf:61ff:fe3d:37b1%13
192.168.12.1
DHCP Server . . . . . . . . . . . : 192.168.12.1
DHCPv6 IAID . . . . . . . . . . . : 191372783
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2E-FF-4D-CA-68-1D-EF-41-2D-CC
DNS Servers . . . . . . . . . . . : 192.168.12.1
fdb3:7af:639e::1
NetBIOS over Tcpip. . . . . . . . : Enabled
I found the IP address by looking at the Tail Scale results for win11
Thank you
Kevin
PS would a router do anything for my setup
The t-mobile box is both a modem and a router. So no don’t buy a router. Why are you trying to use a Ethernet adapter on an iPad? Just join the WiFi.
Thought I had to because of the LAN
I was asking about using WiFi with the LAN I thought it would be incapatible because I was using the wrong address
Tail Scale gave me the correct address
For some reason when I used CMD on win/ ipconfig/all I didn’t
See the address under Ethernet
Maybe I used the wrong request
Thank You Kevin
It's a bit confusing because your subject is about a laptop which you never mention again and then you throw in an iPad and Tailscale.
For someone to help you with networking, at the minimum they need to know what devices you have, how they're connected to your network and what their IP addresses are.
