Connection issue yes and no
So I have Channels installed on one TV (onn box) and it works fine. I installed the app on another TV (also onn box) and the app can't find the Channels server. Both on the same network. WTH? Any ideas?
Mine works just fine. Do you know how many connections you’re allowed?
Are you sure it's the same network? What's the actual topology?
If you want actual help, share actual details.
I have a Google TV that kept trying to connect to MAC address, so it failed. I just had to manually put in the local IP address and it connected fine after that point.
