Started with turning off the WiFi, had the issue come up again this morning. Submitted another log.
Trying without Tuner Sharing now. Haven’t had any issues with it since it’s launch so hoping there’s a solution that will allow Tuner Sharing to work if it ends up being the issue.
Just noticed this in the DVR log as well:
2017/10/18 06:56:22 [TNR] Opened connection to 1044EEE8 for ch7.1 2017/10/18 07:24:09 [DVR] Cancelling stream 1044EEE8 ch7.1 after 3s read timeout 2017/10/18 07:24:09 [TNR] Closed connection to 1044EEE8 for ch7.1
EDIT:
Without Tuner Sharing, got an hour without any issues. Switched back to Tuner Sharing and had issue again. Same entries in the log:
2017/10/18 09:00:28 [TNR] Opened connection to 1044EEE8 for ch7.1 2017/10/18 09:10:54 [DVR] Cancelling stream 1044EEE8 ch7.1 after 3s read timeout 2017/10/18 09:10:54 [TNR] Closed connection to 1044EEE8 for ch7.1
I recently updated to macOS 10.13 and reset my energy settings. I’m going to try for the next few hours with Tuner Sharing on but prevent my DVR computer from sleeping.
