@tmm1 installed it, restarted, still same issue sadly.
Not sure if the redirect headers are right? But I'm not very technical
referrer header was just my guess @tmm1
Anyway to debug what headers are being sent?
If I can get the headers its sending to the redirected url, I can figure out which one is causing issues
Hmm would have to use something like Proxyman to see what's happening. The links don't work for me, but maybe I can see what the headers are.
@tmm1 is THIS proxyman log of any help? I downloaded Proxyman, watched Channel 3 (which worked) then tried TVNZ 2 which is one of the channels that has the issue.
This pre-release fixed it! Working like a charm now.
@tmm1 and @matthuisman thanks for your help with this matter.
oh wow! neat!!
Ive been meaning to get back to this to try debug myself!
@tmm1 may I ask what was the fix? Was it referrer being sent?
@slampman interested to hear if this also fixed your issue with Three, Duke and Eden
@matthuisman Duke started working a couple of weeks ago. I just tried three and Eden and still getting 503 errors. I can watch via browser directly from the source jus not through channels
@slampman
You sure you on v2025.06.11.0058 ?
There were multiple attempts at fixing I believe
Maybe your issue is different.
Threes direct url is: https://fv23-three.fullscreen.nz/index.m3u8
If you put that into channels - you say it works?
Are you physically in NZ?
If your using a vpn or smart dns then i suspect it isnt working correctly for channels?
