I'm out of ideas unless you have an ad blocker or it's your AV software.
When I try Three I get redirected to fullscreen.nz and cloudfront gives me a 403 error (geo-blocked, I'm sure). But trying One and Two both redirect me directly to cloudfront.net
May be worth trying a different DNS provider to test, like one of the QUAD DNS servers.
If i added a referrer header, i get the same 403 error.
Without, i get the playlist fine
@tmm1
Do you know if any referrer header is added on redirects in Channels?
Will a "Referrer-Policy: no-referrer" help on my side when returning redirects?
I recall Kodi had the same issue at some stage so I started adding "referrer:" to the piped kodi headers to force it to not send it.
Actually, I PRd to remove that here:
Turn off CURLOPT_AUTOREFERER
I don't believe this would work for Channels though?
That's VERY interesting. Firstly, I couldn't import the cloudfront m3u8 directly into Channels Sources, got an error. Imported the raw IPTV link into iptveditor, manually changed the source for TV1 from mjh.nz to cloudfront:
I imported the playlist into Channels using iptveditor link. TV3 worked as per above, TV2 failed as per above BUT.... this time TV1 worked!
So the direct cloudfront link (via iptveditor) worked great!
2025/06/09 21:25:48.795339 [TNR] Opened connection to M3U-CloudfrontTestviaIPTVEditor for ch3 Three
2025/06/09 21:25:48.795339 [HLS] Starting live stream for channel 3 from 192.168.88.9 (bitrate=8461kbps)
2025/06/09 21:25:49.559468 [HLS] Session ch3-dANY-ip192.168.88.9 started in 764.1285ms
2025/06/09 21:25:49.657149 [HLS] Probed live stream in 861.1466ms: h264 1920x1080 progressive 3809753bps
2025/06/09 21:25:56.698708 [HLS] Stopping transcoder session ch3-dANY-ip192.168.88.9 (out=14.388s finished=false first_seq=1 last_seq=7)
2025/06/09 21:25:56.699212 [TNR] Closed connection to M3U-CloudfrontTestviaIPTVEditor for ch3 Three
2025/06/09 21:25:56.703167 [SNR] Buffer statistics for ch3 Three: buf=0% drop=0%
2025/06/09 21:25:56.703167 [SNR] Streaming statistics for ch3 Three: timeouts=0 segment_timeouts=0 playlist_timeouts=0
2025/06/09 21:26:00.671630 [ERR] Failed to start stream for ch2: M3U: Could not fetch playlist from i.mjh.nz: GET: https://i.mjh.nz/.r/tvnz-2.m3u8: 403 Forbidden
2025/06/09 21:26:00.680505 [HLS] Couldn't generate master playlist for ch2-dANY-ip192.168.88.9: M3U: Could not fetch playlist from i.mjh.nz: GET: https://i.mjh.nz/.r/tvnz-2.m3u8: 403 Forbidden
2025/06/09 21:26:00.680505 [HLS] Stopping transcoder session ch2-dANY-ip192.168.88.9 (out=0s finished=false first_seq=0 last_seq=-1)
2025/06/09 21:26:12.121904 [TNR] Opened connection to M3U-CloudfrontTestviaIPTVEditor for ch1 TVNZ 1
2025/06/09 21:26:12.121904 [HLS] Starting live stream for channel 1 from 192.168.88.9 (bitrate=3281kbps)
2025/06/09 21:26:12.882905 [HLS] Session ch1-dANY-ip192.168.88.9 started in 761.0014ms
2025/06/09 21:26:12.972889 [HLS] Probed live stream in 850.4772ms: h264 1280x720 progressive 1771303bps
2025/06/09 21:26:21.981711 [HLS] Stopping transcoder session ch1-dANY-ip192.168.88.9 (out=13.418667s finished=false first_seq=1 last_seq=7)
2025/06/09 21:26:21.982249 [TNR] Closed connection to M3U-CloudfrontTestviaIPTVEditor for ch1 TVNZ 1
2025/06/09 21:26:21.986322 [SNR] Buffer statistics for ch1 TVNZ 1: buf=0% drop=0%
2025/06/09 21:26:21.986322 [SNR] Streaming statistics for ch1 TVNZ 1: timeouts=0 segment_timeouts=0 playlist_timeouts=0
@matthuisman here is the crazy thing. I have zero issues getting tvnz1 and tvnz2 using the raw m3u. However I have never been able to get Three, Duke, or Eden to work. Do you have those direct urls so I could test this theory on those channels?
Ahh, yes. Unless you use a browser (like Brave) that tells you where the file is being downloaded from,
you would have to use your browser network inspector to see the location in the response header of the 302 redirect from mjh.nz
or look at the redirected get
FF will let you copy the Download url for saved downloads
Bing - thats why i use redirects so your links dont get outdated.
I think nz urls dont change that often so might be safe,
But i dont want to be constantly asked when they change.
id rather we work with @tmm1 to figure out why the redirects are not working.
I still suspect referer header is being added?
No I hadn't but I just installed the latest pre-release 2025.06.10.1557, re-started, held my breath and.... sadly let it out again. Still the same error
2025/06/11 11:06:40.153543 [ERR] Failed to start stream for ch2: M3U: Could not fetch playlist from i.mjh.nz: GET: https://i.mjh.nz/.r/tvnz-2.m3u8: 403 Forbidden
2025/06/11 11:06:40.153543 [HLS] Couldn't generate stream playlist for ch2-dANY-ip127.0.0.1: M3U: Could not fetch playlist from i.mjh.nz: GET: https://i.mjh.nz/.r/tvnz-2.m3u8: 403 Forbidden
2025/06/11 11:06:40.153543 [HLS] Stopping transcoder session ch2-dANY-ip127.0.0.1 (out=0s finished=false first_seq=0 last_seq=-1)
